headlight removal - JeepForum.com
post #1 of 7 Old 10-02-2003, 03:15 PM Thread Starter
nefros
headlight removal
ok, im a newbie, how do you remove the headlight from a 95 zj?
nefros is offline
post #2 of 7 Old 10-02-2003, 05:07 PM
boing
This is alll covered in the OWNERS MANUAL.
Boing
boing is offline
post #3 of 7 Old 10-02-2003, 11:20 PM
atlien928
atlien928's Avatar
well i have a 1996, and it sounds stupid, but you just grab the light and pull hard. it's held in by 3 clips, its a really pain to get them out too. the key is pull hard, but dont break the clips, try in warm weather or after the engine is warm and warmed the plastic clips. good luck
atlien928 is offline
post #4 of 7 Old 10-03-2003, 12:45 AM
whitevette
whitevette's Avatar
Removal of the bulb or the whole housing?
Darkness is deaths ignorance, and the Devils time.
'96 Grand Cherokee Laredo
'93 Taurus SHO
'77 Corvette L-48
'74 Land Cruiser FJ40
whitevette is offline
post #5 of 7 Old 10-03-2003, 09:12 AM
atlien928
atlien928's Avatar
the whole housing. to take out the bulb you have to twist off this large plastic thing that holds the bulb in behind the housing. thats aloso a pain tho. there really is no easy way. i actulyl find taking the housing out easier then taking just the plastic lock off, because then it's easier to take the bulb out of the houseing once the housing is out, because the battery is in the way on the right head light. check out my website, i totally redid my headlight to e-code lights, then put in HID lights in them.
post #6 of 7 Old 10-06-2003, 02:57 PM
imnotu
imnotu's Avatar
i've got a 95 zj and just changed mine this morning when the bulb went driving home. the one by the battery isnt hard, there was something holding the battery down, i just took that off real quick and leaned the battery back an inch. to remove the power plug to the bulb, you'll notice theres a little clip on it. i jiggled the wire for a min and it popped the clip off. after that there's a white plastice piece surrounding the bulb, turn it counter clockwise (toward the driver seat if you are facing the front of your jeep). it will turn a little then pop out. after that just pull the bulb out and pop in your new one. put the plastic pice back in, then the power clip, then adjust that thing that held the battery. any? i did this in 10 minutes today and it only took me that long bc i couldnt figure out how to get my hand to the light (and yes i am a new-bie like all hell, but hey i read my manual and do my best).
hope that helps u some, if it doesnt let me know i'll take a pic if you want.
--luke
I6 w/ Selec-Trac, Plush Leather Seats (powered in front), JVC MP3 deck (STOLEN),
(Insurance messed up and gave me this instead),
, Remote Start, Optima Red Top, 180 Thermostat, Kolak Performance 2.5" exhaust components: (Car Sound high flow converter, Magnaflow large case muffler, mandrel bent tailpipe), 16x8 Rubicon Rims with 245/70 Bridgestone Dueler A/T Revo Tires, Rancho SS, Mopar Skids all around, Tow hooks front and back, Bilstein Heavy Duty Shocks and Clear Corners. [B]149/B], and still going stro... OK My transfer case can a small leak... damnit!.
imnotu is offline
post #7 of 7 Old 10-06-2003, 03:29 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I recently changed out my bulbs with the sylvania silver brights or whatever you call them. Much better. If you do some searching on JU there are some threads about cleaning the inside of the housing when it starts to get dirty or yellowed.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
ZJ headlight removal? uncc09meet ZJ Grand Cherokee Forum 34 01-23-2015 06:22 PM
98 Headlight removal quick66ss ZJ Grand Cherokee Forum 3 09-25-2009 06:14 AM
92 ZJ headlight removal calvin12 ZJ Grand Cherokee Forum 2 01-07-2006 03:21 PM
Headlight removal Othoni ZJ Grand Cherokee Forum 9 03-07-2005 12:10 AM
Removal of ZJ headlight??? Need4Boost ZJ Grand Cherokee Forum 6 02-04-2003 12:06 AM
