Headlight lens removal - JeepForum.com
post #1 of 21 Old 11-09-2004, 09:17 PM Thread Starter
CTJeeper
1995 XJ Cherokee
Try as I might, I have not found any instructions on how to remove and replace the headlight lenses on my 1995 Jeep Grand Cherokee. Is it as simple as removing the bolt at the top on the cross member, and then yanking the unit up and out?
Or is there something holding it in place on the bottom that must be loosened or removed first. Thanks for your help!
CTJeeper is offline
post #2 of 21 Old 11-09-2004, 09:26 PM
Meerkat
There is no bolt or screw to remove.
The headlight simply pops off. If it hasn't been removed in a while, it is going to be hard to remove, but it will come off.
Just grab the bottom of the housing with your fingers and snap it toward you. The bottom will pop off. Then you can snap the top off. It's held on by three snap fit ball and socket connectors.
Here's a helpful hint... Apply a this coating of lithium grease to the sockets before replacing the assembly.
BTW, why do you want to remove the housing? It's not necessary if you are needing to change the bulb...
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 21 Old 11-09-2004, 09:32 PM Thread Starter
CTJeeper
1995 XJ Cherokee
Why I'm replacing
Over time the lens on the original unit has gotten all yellow and faded and crusty and spreads the light all over the place. The new units I'm dying to put in are crystal clear. I'm headed out to the driveway right now to try it. Wish me luck!
And thanks for your reply. I'll let you know how I make out in a little bit.
CTJeeper is offline
post #4 of 21 Old 11-09-2004, 09:35 PM
Meerkat
Good luck!
Warren
Meerkat is offline
post #5 of 21 Old 11-09-2004, 10:15 PM Thread Starter
CTJeeper
1995 XJ Cherokee
done with it
Getting them off was a snap. Getting the new ones on was not as easy. The aftermarket units didn't snap on as easily as I had hoped. Had to be very careful to line them up and even then it wasn't easy. But it's done and it looks and works a lot better. thanks for your help!
CTJeeper is offline
post #6 of 21 Old 11-09-2004, 10:18 PM
Meerkat
Glad they worked out for you.
Now have a beer!
Warren
Meerkat is offline
post #7 of 21 Old 02-19-2013, 02:08 PM
sangfarmer
1996 FSJ Cherokee
Valuble info
Used this guide to remove my lens and worked perfectly but you can also use a claw hammer laying on the lens horizontally and pry against the cross member to pop the top out. Be sure to check and replace your other bulbs and lubricate the adjustment screws while you have the lens out. Oldie but a goodie.
sangfarmer is offline
post #8 of 21 Old 02-19-2013, 04:03 PM
beaver2low
1994 ZJ
headlights with yellow tint
whats an easy way to clean up a set of headlights with a yellow tint. i am doing this on a real small budget. i heard toothpaste works. what is your suggestions.
beaver2low is offline
post #9 of 21 Old 02-20-2013, 08:34 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
It has to be a baking soda based tooth paste. Or baking soda...
Polishing compound works.
The actual headlight restore kits are cheap too.
ratmonkey is offline
post #10 of 21 Old 02-20-2013, 10:06 AM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Wet sand them, clean with nail polish remover, buff them with rubbing compound, then paint 'em with clear coat.
In the garage: M1 4bbl
McCloudsZJ is offline
post #11 of 21 Old 08-27-2017, 07:34 AM
JeepLady2006
Do you think I need to replace the gasket around the headlight assembly or just replace the lenses on my 2006 Jee[ Grand Cherokee to get rid of the moisture and fogginess? What is really weird is it is in one headlight only. I do not take my car thru automatic washers to avoid this issue but yet I have it anyway. Any suggestions?
JeepLady2006 is offline
post #12 of 21 Old 08-27-2017, 10:26 AM
vlackattack
This thread is 2 years older than your Jeep and in a forum for Jeeps 2 generations older. Try posting over here: http://www.jeepforum.com/forum/f67/
vlackattack is offline
post #13 of 21 Old 09-02-2017, 11:19 PM
dodgemahally
Replaced mine and it was a *****. Corrosion and broken plastic parts added up to a cluster. Done, but it's not good......adjusters are totally ganked up. And, one outside lower ball socket was toast and won't connect. I'm not happy.
dodgemahally is offline
post #14 of 21 Old 09-03-2017, 12:31 AM
Uniblurb
Uniblurb's Avatar
Yeah Dodge, my headlamp replacements 4 years ago turned into a nightmare too. Here's the thread and there should be some replacement adjuster/clip part numbers which may be able to help you out. Real good tip by Highlonesome at the end to heat the headlight assemblies up with a heat gun or blow drier. Good luck.
http://www.jeepforum.com/forum/f13/n...uster-1516169/
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #15 of 21 Old 09-05-2017, 11:25 AM
dodgemahally
Thanks Uni for the link to that thread. I wish I would have thought about using a heat gun. I use it often to attach hard plastic parts.......just didn't enter my mind, dangit. New headlites are installed but it's not right.(Is there lenses made in the USA?) I will read carefully all the posts of your headlight thread and hopefully come up with a solution. Don't ever leave us.
Headlight Lens Restore Tutorial BucYouUp68 WJ Grand Cherokee Forum 83 09-21-2012 01:43 AM
What kind of replacement ZJ headlight lens? handee521 ZJ Grand Cherokee Forum 23 01-12-2009 10:03 PM
96 GC Cloudy Headlight Lens tthomas436 ZJ Grand Cherokee Forum 17 08-01-2005 09:22 PM
Headlight removal Othoni ZJ Grand Cherokee Forum 9 03-07-2005 12:10 AM
headlight removal nefros ZJ Grand Cherokee Forum 6 10-06-2003 03:29 PM
