headlight adjustment? - JeepForum.com
post #1 of 2 Old 03-15-2004, 07:32 AM Thread Starter
73Bird
I have a lifted 95 ZJ and the headlights dont hit the road at all because of the lift.
can anyone tell me how to adjust them?
Thanks in advance.
73Bird is offline
post #2 of 2 Old 03-15-2004, 07:52 AM
Meerkat
Thanks in advance.
Park on level ground 25 feet away from a convenient wall. Make a reference line about 3 feet off the ground on the wall using tape. Open your hood and looke at the crossmember just above and to the rear of your headlights (but in front of the radiator). You'll notice a couple holes behind the headlight with a torx head screw in each one. With your headlights on low beam, note where the center of the beam strikes the wall relative to the marker tape (probably high). If I remember correctly, turning the outboard torx screw adjusts your headlight up and down, the inboard screw adjusts in and out. Adjust your headlights down until the center of your beam is at the tape. Also make sure the beam is pointing straight ahead on each one. You can do the same for your driving lights, but adjust them for about 1 to 1.5 feet up the wall.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
HELP my headlight adjustment screw is only turning 1 way. NeverL8 ZJ Grand Cherokee Forum 4 02-07-2010 01:12 PM
2000 Headlight adjustment question Be-O-Be ZJ Grand Cherokee Forum 8 12-18-2009 09:07 PM
05 WK Headlight Adjustment? Stricken WK Grand Cherokee & XK Commander Forum 2 05-08-2008 07:14 AM
WJ headlight adjustment Tdad ZJ Grand Cherokee Forum 0 12-16-2006 09:33 AM
Headlight adjustment okflgator ZJ Grand Cherokee Forum 3 06-09-2003 10:54 PM
