headlamp fog removal - JeepForum.com
post #1 of 8 Old 10-19-2008, 09:58 PM Thread Starter
nickaplease03
I just had a quick tip for TEMPORARY removal of the infamous fog/haze on the headlights.
Use a little bit of motor oil (wd-40 works too) on a rag to buff out the haze. Works great for a few days, then needs to be repeated. Has something to do with the oil filling in the cracks on the plastic/glass gives the illusion of a smooth surface.
Any other tips for clearing up this haze?
nickaplease03 is offline
post #2 of 8 Old 10-19-2008, 11:05 PM
elmer_fud
you can try a clear coat paint. It will do the same thing as wd40 with respect to filling in the cracks.
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #3 of 8 Old 10-19-2008, 11:47 PM
kidA
toothpaste
kidA is offline
post #4 of 8 Old 10-20-2008, 12:36 AM
MEinSoCal
wet sanding seems to be the best method followed my some polishing compound
MEinSoCal is offline
post #5 of 8 Old 10-20-2008, 08:32 AM
MeWJWifeZJ
replacement works the best that I've found..... I tried wet sanding and buffing, I tried plastic polish, I tried Toothpaste, oil actually dries the lenses out and makes them brittle after time.
Praise to a Child is like Sunlight to Flowers
Traded away the WJ to get a commuter
We finally got another Jeep after 5 years without. Too bad it's ALL stock.
MeWJWifeZJ is offline
post #6 of 8 Old 12-03-2008, 07:50 PM
99jeepercreeper
Originally Posted by kidA View Post
toothpaste
Toothpaste + Peanut Butter (about 50/50) + a touch of water...
Mix it up, get some 2k grit sand paper, and apply.
It clumps up and doesnt seem to "spread" on the headlight, but it will still work. It's the wet sanding and the moisture left from the mixture that works. At least it did for me. For denser fog use a lower grit paper, like 600 or 1k.
Good luck.
99jeepercreeper is offline
post #7 of 8 Old 12-03-2008, 07:52 PM
99jeepercreeper
toothpaste
It clumps up and doesnt seem to "spread" on the headlight, but it will still work. It's the wet sanding and the moisture left from the mixture that works. At least it did for me. For denser fog use a lower grit paper, like 600 or 1k. Then add some wax or some people have had luck with some armor-all products.
Good Luck.
post #8 of 8 Old 12-04-2008, 05:30 AM
cirame1
i just bought this compound in a blue bottle at auto zone the other day said removes headlight yellowness and hazyness. put some on a rag and rubbed in for a minute then rubbed off with another rag and it took all the yellowish and haze off almost looks brand new again. was like 5 bux or sumthin on the end of the aisle.
cirame1 is offline
Headlamp adjusters Mooman ZJ Grand Cherokee Forum 7 12-05-2008 02:49 AM
Headlamp Switch Jo060 ZJ Grand Cherokee Forum 6 06-13-2008 10:39 AM
What is this part? and question on headlamp removal sabre364 WK Grand Cherokee & XK Commander Forum 6 06-12-2008 09:19 AM
headlamp zj removal/replacement kd6zxe ZJ Grand Cherokee Forum 5 12-20-2006 09:50 AM
Is this possible. WJ Headlamp+Grill in ZJ Ruffy ZJ Grand Cherokee Forum 5 01-05-2005 02:30 PM
