Header swap (true or false)??? - JeepForum.com
post #1 of 15 Old 07-05-2013, 09:26 PM Thread Starter
JayRay08
I read somewhere that a good exhaust header swap as an upgrade to the 318 5.2 v8 zj would be headers from 92-93 dodge trucks, vans, dakotas as well as the 93 ZJ. anyone have knowledge of this? would this be a good cheap upgrade if pulled from a salvage yard??
JayRay08 is offline
post #2 of 15 Old 07-05-2013, 09:28 PM
dnuccio
no. any exhaust manifold from a full size dodge anything is going to dump straight into the "frame" rail of the ZJ.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 15 Old 07-05-2013, 09:57 PM Thread Starter
JayRay08
Ok so the only upgrade to the exhaust would be a new cat and a performance muffler. This is my first time messing with exhaust. Would i want 2.5 inch pipe from the manifold to the cat? Would that also mean i am looking for a 2.5 inch inlet and outlet for the cat and muffler? sorry for the noob question.
JayRay08 is offline
post #4 of 15 Old 07-05-2013, 10:21 PM
Mickey_D
Talk to Kolak. He's a member on here as well as one hell of a vendor.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #5 of 15 Old 07-06-2013, 09:16 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Some stock 93 ZJ V8 exhaust manifolds are supposed to flow better. I have no idea how to spot them or how much better they are. speedfreaks.net has some info.
HighLonesome is offline
post #6 of 15 Old 07-06-2013, 09:27 AM
Pierre_r
1989 XJ Cherokee
I bought the doug thorley headers from kolak.
They are a litte pricey but if you want to go 3" all the way they are worth it according to all of those who have them on their jeeps. + they look much nicer than the stock manifolds...
Pierre_r is offline
post #7 of 15 Old 07-31-2013, 08:36 PM Thread Starter
JayRay08
any thoughts on these http://www.jegs.com/i/Hedman/500/785...d=#moreDetails
or another brand that wold work well?
JayRay08 is offline
post #8 of 15 Old 07-31-2013, 08:53 PM
dnuccio
you cant just find headers for a 318/360. they need to be specifically designed for a ZJ. most if not all aftermarket headers (that arent designed specifically for the ZJ) dump right into the ZJs frame rail
R.I.P. Ratmonkey
dnuccio is offline
post #9 of 15 Old 07-31-2013, 08:57 PM Thread Starter
JayRay08
I was reading thru ratmonkeys thread and thought he had used those..
JayRay08 is offline
post #10 of 15 Old 07-31-2013, 09:00 PM
dnuccio
he mightve. i dont know for sure
R.I.P. Ratmonkey
dnuccio is offline
post #11 of 15 Old 07-31-2013, 10:11 PM
newfieZJ
He did but had no choice . His trans swap was from a Dodge putting the starter on the driver's side . This was his only option and if Kolak sold out the last batch of Thorley's , our only option .
With them , comes the fabrication of the y-pipe . Can get pricey if you can't do it yourself
I have headers and love them , but , from now on , I will have to be content with making a new y-pipe with 2.5 pipe and no crush on the pass side (tight) . Supposedly , removing the crushed pipe adds approx 10 hp alone , probably 10+ more with bigger y-pipe . That will be close to header capability .
Biggest gain comes from a new cat and muffler . 2.5" works fine unless you have headers or modify the y-pipe .
IIRC , the 93's had a larger outlet on the manifold .25" bigger . Early production only . Hard to spot like you said HL , hard to find period .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #12 of 15 Old 07-31-2013, 10:15 PM
StPaul59
Some Dakota shorty headers will work. Ratmonkey was using them I think.
StPaul59 is online now
post #13 of 15 Old 08-01-2013, 09:21 AM Thread Starter
JayRay08
thanks for clarifying that newfieZJ. Ive read people throwing around edelbrock having some but I haven't found em yet. do you know if they still make them and if so can you link it here?
JayRay08 is offline
post #14 of 15 Old 08-01-2013, 09:31 AM
newfieZJ
Edlebrock stopped making the some time ago . I have them , they are very good . No issues since the install . only a 2.5 collector but they work well . I got them for $250 delivered to my door under a 1/2 hour , 2nd hand but new . Guy needed some $$$
Post 26 has a pic of the complete Edlbrock kit
http://www.jeepforum.com/forum/f197/...86/index2.html
newfieZJ is offline
post #15 of 15 Old 08-01-2013, 10:52 AM
CatSplat
1994 ZJ
IIRC he had to notch his frame to make those ones fit.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
