head gasket or exhaust problem???? - Page 2 - JeepForum.com
post #16 of 16 Old 08-08-2009, 12:08 PM Thread Starter
donha1mn
Originally Posted by jeep95xj View Post
Do you have a check engine light on? Most likely if your cat is bad the CEL will come on. If you dont then just get under your jeep and hit the cat with a closed fist. Sometimes when it's broken up inside it will rattle all around when you hit it.
No check engine light. Could I possibly have bad O2 sensors even though they are only a few months old?
Originally Posted by Double E View Post
Give it a kick or with a rubber mallet to see what may rattle around in there. You may have more than one issue however and I'm still suspicious of the cooling system.
"Im not losing an excessive amount of coolant but I did notice this black gunky stuff underneath my radiator cap and there was like little sparkle things floating on top of my coolant. I opened up my coolant reservoir and it looks a little brown around the edges."
Pull that reservoir and flush it out. Replace, Fill it, draw a line on it & monitor it.
Im gonna have to wait to at least tomorrow to anything since its been pouring outside all day. Ill update once its nice enough to do some work.
5.9 ZJ with some stuff
RIP TROY
RIP RATMONKEY
donha1mn is offline
4.7l oill fill spout gunk! Head Gasket? Cracked Head? kc8ztw ZJ Grand Cherokee Forum 10 10-29-2009 11:49 AM
Will a cracked head or head gasket...... jpl ZJ Grand Cherokee Forum 2 03-04-2009 09:35 AM
Replaced head gasket but still have a problem luca1014 ZJ Grand Cherokee Forum 6 11-07-2008 05:00 PM
head gasket jeepmoney ZJ Grand Cherokee Forum 23 10-03-2008 10:24 PM
99 4.7 Head Gasket -- Please help 99WJ4.7limited ZJ Grand Cherokee Forum 4 07-28-2006 03:54 AM
