Hazards work, turn signals dont - JeepForum.com
post #1 of 4 Old 06-19-2011, 08:12 PM Thread Starter
AKShaolin
I recently went on a camping trip with my friends in my '98 ZJ. After leaving the gas station on the way back into town my turn singals no longer worked (and weirdly neither did my overhead console), but my hazards did.
My buddy and I checked stuff and determined that the fuses and the electronic flasher were all good. We dissassembled the multifunction casing around the steering wheel to check the hazard/turn signal switches.
We found that the right light always flashed when the hazards were on but the left was really sensitive to switch placement (it would work with the hazard switch half-pressed in and turn off when the turn signal lever was fiddled with) and it could just be due to the fact that the part is older and has worn out.
I would love a quick and easy fix and any help would be much appreciated. Im going to look for another MF switch and it would be nice to know if this would indeed fix it. Also, if anyone knows whats up with the overhead console that would be awesome also, although it is far less urgent.
UPDATE: Fuse 6 turned out to be faulty and powered both.
AKShaolin is offline
post #2 of 4 Old 09-04-2011, 09:56 PM
PurpleZJ
dude. you are my hero. all this happened to my zj and i havent been able to figure it out. i coulda swore i checked every single fuse. replaced the number 6 fuse and bam. everything works. thank you for editing your post with the solution.
1996 ZJ- 4.0, AX-15 5SPD/NP242, RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
RIP Troy (bigbluezj94) you wont be forgotten
December 2010 GCOTM
5spd ZJ Club Member 001
Glad you are ok. If you were a cat, you would be down to 8.:D
Originally Posted by Greengc4x4 View Post
Everything looks great, Hellen Keller! :D
Originally Posted by rritch View Post
plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:
RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11
PurpleZJ is offline
post #3 of 4 Old 09-07-2011, 03:51 AM Thread Starter
AKShaolin
no problem at all! i guess it always pays to check and double check before you go crazy trying ot figure it out
post #4 of 4 Old 09-07-2011, 08:57 AM
PurpleZJ
haha go crazy? like take apart the whole bottom of the dash?? yeahhh...... lol
December 2010 GCOTM
04/28/58-2/13/11
PurpleZJ is offline
hazard switch , overhead console , problems , relay , signal lever
No turn signals but hazards work SJErick ZJ Grand Cherokee Forum 5 04-27-2014 07:40 PM
no hazards or turn signals Travis873o ZJ Grand Cherokee Forum 7 09-21-2011 07:00 PM
Turn signal and hazards don't work eliX0r ZJ Grand Cherokee Forum 2 02-27-2011 05:59 PM
ZJ blinkers work, hazards dont MurdaJs ZJ Grand Cherokee Forum 29 09-21-2010 04:53 PM
'01 WJ Limited no turn signals or hazards compcrasher86 ZJ Grand Cherokee Forum 23 06-20-2009 02:19 PM
