having trouble with 1994 jeep grand cherokee - JeepForum.com
post #1 of 4 Old 04-17-2008, 07:47 PM Thread Starter
rgrocks
Bought it about a year ago and had this strange popping noise whenever i turn the wheel. thought nothing of it but now it is beginning to be more frequent. like i said it is only when i turn the wheel and it feels like it is on the left side of the car. i can feel it on the floorboard also. I had a friend look at it he said it was a ball joint, had a mechanic give an estimate and he said it was a trac bar. but it is not showing any other symptoms of the tac bar "dealth wobble" as they call it.
please if somene could point me in the right direction i would be forever grateful. thank you
rgrocks is offline
post #2 of 4 Old 04-18-2008, 06:19 AM
EvilM0nkey
EvilM0nkey's Avatar
try asking here http://www.jeepforum.com/forum/f13/
-Ross
EvilM0nkey is offline
post #3 of 4 Old 04-18-2008, 08:39 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
If it a 94 with a lot of miles, everything probably has a lot of wear...balljoints, TREs, trackbar, control arm bushings, swaybar bushings, hub bearings, maybe steering box.
The thing to do is have a helper turn the steering wheel back and forth whilst you get under there and look for slop at critical points like balljoints, trackbar ends, and TREs. If you can hear it, that will help.
HighLonesome is offline
post #4 of 4 Old 04-18-2008, 08:48 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Mine was doing the same thing. Felt like it was on the left side, and could feel it in the floor when I turned.
What it turned out to be was where the track bar mounts to the axle, the hole was ovaled out, and the track bar was popping around.
Eventually, the bolt wobbled around enough to work the nut off, and the bolt fell out while going down the highway. WORST death wobble EVER! No track bar @55mph = not good.
I had a grade8 washer welded to the mounting bracket to repair the ovaled hole, put an adjustable track bar on, and it hasn't popped since.
'09 Rubicon
Kruzin is offline
1994 jeep grand cherokee laredo will not start mikemedic ZJ Grand Cherokee Forum 16 04-16-2013 11:41 AM
My 1994 jeep grand cherokee pics turnerjc03 ZJ Grand Cherokee Forum 17 07-10-2008 06:23 PM
1994 Jeep Grand Cherokee Climate Control LED jeeplovah ZJ Grand Cherokee Forum 1 06-04-2008 05:19 PM
1994 Jeep Grand Cherokee bohawg ZJ Grand Cherokee Forum 5 03-30-2008 03:32 PM
1994 Jeep Grand Cherokee jasoncam ZJ Grand Cherokee Forum 0 07-15-2002 06:30 AM
