have DW - going to junkyard - JeepForum.com
post #1 of 9 Old 07-20-2009, 12:19 PM Thread Starter
spikeystrip
1993 XJ Cherokee
i have DW on my daily driver and it came out of no where. its a 95 GC AWD with the 5.2 with 200K. i cannot find any loose parts and i had already replaced the tie rod ends and drag link + sway bar end links. i really dont know what to do and i need this fixed b4 i go back to college in a month. im going to the junk yard and i figured i could grab some stuff and try it out. any major wear items on the jeep? the only thing i can think of is maybe control arm bushings? any help is appreciated thanks
1993 cherokee country.
Rustys 5inch lift
firestone 31x10.5 w/ cragar d windows
1995 Grand Cherokee
Stock Daily Driver
AWD 5.2 V8
spikeystrip is offline
post #2 of 9 Old 07-20-2009, 12:30 PM
mawardjr
what about control arms and their bushings ... good shape?
Bent wheel or out of balance tire can also cause DW .....
Rotate wheels/tires front to back and see if anything changes ... if DW goes away you know it is related to them and not the suspension.
'98 ZJ - "Luxo": Drive train: 4.0L, 42RE, 242, HP30 (Lockright)/8.8 (Detroit) Protection: Skids (Engine, Oil, T-Case, Gas, FLCA,Diff), LP-1 sliders Recovery: Rusty's hooks, Class III Hitch Suspension: RE 4.5" SuperFlex, JKS disco's, RE Monotube, Adj Trackbars Wheel/Tire: TrXus 33x12.5-15, RC's 15X8 3.75"BS Misc: CB, Hi-Lift, Tube Doors
mawardjr is offline
post #3 of 9 Old 07-20-2009, 12:55 PM
Bort62
Control arm bushings. Don't get those from the junkyard.
at 200k miles they are guaranteed to be wasted.
___________
'98 Grand
'60 Ranchero
Bort62 is offline
post #4 of 9 Old 07-20-2009, 03:17 PM
WiCkeDuDe
Hows your steering stabilizer. Usually its there or the trackbar.
WiCkeDuDe is offline
post #5 of 9 Old 07-20-2009, 04:44 PM
JForest2
Can an out of balance tire really cause death wobble? Would jeep really produce a vehicle that would cause this dangerous condition.. I know the short answer is yes.. But I has to be more than that causing this issue..
James
JForest2 is offline
post #6 of 9 Old 07-20-2009, 05:58 PM
skain8
skain8's Avatar
James
Many causes of DW, but yes, one of them is most certainly out of balance/out of round tires.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #7 of 9 Old 07-20-2009, 06:03 PM
ZgreatJ
Rain Man
ZgreatJ's Avatar
Stock heighth? CA bushings or check track bar bolt.
RIG#1 96 Forest Green ZJ Laredo-4.0 I6 242
GREEN JEEP CLUB MEMBER #136
Kevin's 4.5 lift-Kevin's Rock Sliderz-Custom 4X4 Fab Front Winch Bumper-T Max EWI 10000 winch-32X10.50-15 Super Swamper TSL Radials on US Wheel 15X8 Black Steelies-OME SS-Rusty's steering conversion-SOLD
Currently- 98 ZJ Limited-99 XJ Classic-Both stock for now
ZgreatJ is offline
post #8 of 9 Old 07-21-2009, 12:41 PM Thread Starter
spikeystrip
1993 XJ Cherokee
how can i even check control arm bushings? theres no play in them when i pry up on it with a bar or any movement. do i have to take them off and thats the only way? also i didnt check my track bar but when i hit a bump that fully flexes the suspension i hear a clunk on drivers side and i no something is loose but its only so often it makes it hard to track down.
Rustys 5inch lift
1995 Grand Cherokee
Stock Daily Driver
AWD 5.2 V8
post #9 of 9 Old 07-21-2009, 01:33 PM
Bort62
My DW was caused by worn control arm bushings and exacerbated by unbalanced tires.
___________
'98 Grand
'60 Ranchero
Bort62 is offline
97 ZJ Junkyard upgrades? Gibby913 ZJ Grand Cherokee Forum 21 01-04-2013 09:54 AM
Junkyard Lift? kdavis ZJ Grand Cherokee Forum 17 03-21-2012 07:56 PM
junkyard 44a Qs? sandman ZJ Grand Cherokee Forum 5 11-23-2008 02:31 AM
Junkyard Find DTrem08 ZJ Grand Cherokee Forum 12 10-23-2007 12:12 PM
mods from junkyard BustedZJ ZJ Grand Cherokee Forum 11 04-29-2007 08:53 AM
