-   -   have DW - going to junkyard (http://www.jeepforum.com/forum/f13/have-dw-going-junkyard-820652/)
spikeystrip 07-20-2009 12:19 PM
i have DW on my daily driver and it came out of no where. its a 95 GC AWD with the 5.2 with 200K. i cannot find any loose parts and i had already replaced the tie rod ends and drag link + sway bar end links. i really dont know what to do and i need this fixed b4 i go back to college in a month. im going to the junk yard and i figured i could grab some stuff and try it out. any major wear items on the jeep? the only thing i can think of is maybe control arm bushings? any help is appreciated thanks
mawardjr 07-20-2009 12:30 PM
what about control arms and their bushings ... good shape?
Bent wheel or out of balance tire can also cause DW .....
Rotate wheels/tires front to back and see if anything changes ... if DW goes away you know it is related to them and not the suspension.
Bort62 07-20-2009 12:55 PM
Control arm bushings. Don't get those from the junkyard.
at 200k miles they are guaranteed to be wasted.
WiCkeDuDe 07-20-2009 03:17 PM
Hows your steering stabilizer. Usually its there or the trackbar.
JForest2 07-20-2009 04:44 PM
Can an out of balance tire really cause death wobble? Would jeep really produce a vehicle that would cause this dangerous condition.. I know the short answer is yes.. But I has to be more than that causing this issue..
James
skain8 07-20-2009 05:58 PM
219 Attachment(s)
James
Many causes of DW, but yes, one of them is most certainly out of balance/out of round tires.
ZgreatJ 07-20-2009 06:03 PM
Stock heighth? CA bushings or check track bar bolt.
spikeystrip 07-21-2009 12:41 PM
how can i even check control arm bushings? theres no play in them when i pry up on it with a bar or any movement. do i have to take them off and thats the only way? also i didnt check my track bar but when i hit a bump that fully flexes the suspension i hear a clunk on drivers side and i no something is loose but its only so often it makes it hard to track down.
Bort62 07-21-2009 01:33 PM
My DW was caused by worn control arm bushings and exacerbated by unbalanced tires.
The time now is 01:10 AM.
