hatch issues - JeepForum.com
post #1 of 2 Old 09-06-2013, 05:54 PM Thread Starter
LilRedDakota
hatch issues
97 ZJ rear hatch outside handle. A couple of questions. Is the handle the same as XJ? How does this come out? Took the nut off the inside and could not get it to come out of gate. Swapped rotted hatch with another, wanted to swap handle so key would work just in case I needed it. Nut came off fine, of course the old hatch handle stud spun free and I decided to swap just the lock once I got them out. Should have just done this first. went to put nut back on and as per my life, stud spins free in new hatch handle now! Really!?!? Where can I get these from other than JY?
Also how to adjust rear hatch alignment. The top seems ok, the bottom is shifted to the passenger side. The wrap around part just above the taillights is in too far in on driver side and out on passenger side. Took complete hinges with new gate, doesn't seem to be any adjustment at hinges. does the latch piece in the floor move, as long as the bolts don't break when I go to loosen it?
I would like to get this resolved so I can put rear panels back together and move on to t/c swap and axle bearings to make it 4X4 again. Thought this would be quick and easy and get the gate out my garage before it got banged up. Its a matching color and the rear wiper even works on it!!
Need to get back to garage and finish swapping engine in the XJ. Will check back tomorrow when I am awake again.
It's either that, or something else.
LilRedDakota is offline
post #2 of 2 Old 09-29-2013, 08:38 PM Thread Starter
LilRedDakota
bump
