Has anyone replaced their AM / FM Antenna ? - JeepForum.com
post #1 of 7 Old 07-21-2013, 10:01 AM Thread Starter
Lakoswolf
Greetings all,
I have been thinking about replacing my AM / FM antenna since the mast broke off earlier this year. From what I can gather the base and Lardeo models came with non-powered antennas, my ZJ is a limited. I am under the impression then, that this antenna is powered, although I can't say that I've ever seen it actually move up or down etc. Has anyone replaced just the mast, or the entire unit? Honestly I'd just like to replace the mast itself, I could care less if it moves. Furthermore in the interest of a possible CB install in the future, is there a way to combine a CB and AM /FM antenna setup?
Any thoughts or advice on the matter would be appreciated. Thanks in advance.
"Those who say it cannot be done should not interrupt the one doing it." -Chinese Proverb
93' Grand Cherokee 5.2 Ltd. - Mine
93' Grand Wagoneer 5.2- Dad's
93' Grand Cherokee 4.0 Ltd. (Deceased)
Lakoswolf is offline
post #2 of 7 Old 07-21-2013, 04:44 PM
dusterdude
No,only european zg's were powered(iirc).i changed mine,its a pain in the ***.if you want to know more pm me
dusterdude is offline
post #3 of 7 Old 07-21-2013, 05:17 PM
dbabicky
1975 J-Series Truck
My 95 Limited ZJ has a power antenna.(US model)
Why me, Why me !!!
dbabicky is offline
post #4 of 7 Old 07-21-2013, 05:43 PM
dusterdude
Interesting
post #5 of 7 Old 07-22-2013, 05:40 AM
JeepNicholson
Originally Posted by Lakoswolf View Post
Greetings all,
If it easily unscrews, it's a mast. The base is even "nut shaped". Easy peasy.
JeepNicholson is offline
post #6 of 7 Old 07-22-2013, 01:07 PM
zjosh93
My 93 Laredo has a powered mast. Also a US model.
Mine also has power seats and door locks though.
zjosh93 is offline
post #7 of 7 Old 07-22-2013, 01:25 PM
JeepNicholson
It is definitely possible to run both your cb and radio through the same antenna.
Guys I know that have done this usually run their am/fm through the cb antenna and not the other way around because your normal radio antenna is not really well suited for cb transmission due to the way the radio waves work, but am/fm works pretty well through a cb antenna.
antenna replacement , radio
