Has anyone painted the GC rims black? - Page 2 - JeepForum.com
post #16 of 20 Old 10-01-2011, 02:41 AM
MudMad
Originally Posted by cherokeen View Post
Great example! These are the same rims as i have, so i'll be doing pretty much the same as you have seeming as i'm 50% off road most the time too.
What lift do you have?
It's got Up-Country springs and some 1 3/4 inch spring spacers off one of the eBay suppliers, together with some longer Rough Country shocks to suit the new height. It looks higher in the rear in this photo, but the driveway is a bit un-even, so the front is a better indication of height. I noticed that it sat a bit low on the right rear (this is the right hand drive Japanese Import version), which I suspected was the track bar dragging the corner down - although most of the posts on this site that I researched seemed adamant that this indicated a shock or spring sag problem. To test my theory, I did a front to rear spring swap, and this definately made the sag worse, and I was also unhappy with how much off-set the axel had. It also felt really uncomfortable on left hand corners, with quite a distinct understeer feel ...
I bought a front and rear track bar lowering bracket kit from the US, although discovered when it arrived that the left hand (US) and right hand (Japanese) versions must have their running gear reversed or something, because my track bar ran the opposite way to the one in the instructions so the bracket didn't fit. I've fixed this by simply cutting the track bar and extending it with galvanised steel tubing welded over the original bar - looks real strong!
Problem solved. Axel centred and the rear now sits completely level. No more understeer on left hand corners, and rides nice and firm (how I like it on our rough roads here in Northland, NZ) having left the front springs in the rear (without spacers). Tires are 275/70-16 - the metric equivalent of around 31.5 inches.
MudMad is offline
post #17 of 20 Old 10-01-2011, 07:45 AM
PolkaPower
I kept my spacers in the rear along with the bb. In the front I used an extra spacers and sandwiched the bb between it. Leveled it out pretty nice. I would watch that drop bracket closely. Looks good with the wheels black. I did this to my 95 limited rims because they were trashed. It turned out great and they never flaked off.
PolkaPower is offline
post #18 of 20 Old 10-10-2011, 03:11 PM
jmonty0523
Has anyone painted other style rims black and put them on a ZJ? I kinda like/want the rounded 5 spoke rims that came on the late 90's Cherokees and Wranglers, but I'm not sure what it would look like when done, and I don't want to go through the investment and have it not come out as expected...
http://www.finishlinewheels.com/JEEP...97/A-09016U85/
Kinda thinkin that rim would look good, but never seen it done and was just curious. I believe it's called the Grizzly rim. Definitely want to stick with the 15X7 because my tires only have 1000 miles on them. I also have seen the aluminum lace rims off of the early 90's Cherokees black with the silver lip, anyone have any pics of either on a ZJ? preferably a white ZJ with Laredo trim?
jmonty0523 is offline
post #19 of 20 Old 09-14-2014, 12:52 PM
slidingstill
Tire size?
[QUOTE=MudMad;12243422]I've painted the factory gold/silver alloys. I used some steelo (scotch) pads to take of the grime, then painted with black enamel etch primer - I prefer the matt rather than gloss finish otherwise the tires tend to look to grey in comparison to the rims.
Have been off-roading plenty of times and no problems so far. I have all the paint gear and plenty of paint, and given that mine is used as a bush basher, it's pretty rare to see the wheels through the mud anyway, so I'm not too fussy if touch-ups are needed in the future.
I like the look of your ZJ especially with the painted tire wheel combo. I have a set of 5 and due to budget and limited resources I want to keep them and wrap them with new rubber. I wanted to ask you what size is that on your ZJ and if possible what is the tallest size and width you could run on those stock rims? Thanks for your time. You can PM me if you like.
slidingstill is offline
post #20 of 20 Old 09-14-2014, 01:08 PM
98318242
The PO of my first jeep sprayed the wheels black. I think it looked good. I still miss that jeep!
98318242 is offline
rims
Painted wheels black... Robb_ ZJ Grand Cherokee Forum 27 12-26-2008 07:48 AM
Black Rims On A WK? RaiderJay6 WK Grand Cherokee & XK Commander Forum 4 03-28-2008 09:14 AM
Pic Request - Black Limited with Gold Trim Painted kdavis ZJ Grand Cherokee Forum 16 09-26-2007 09:18 AM
has anyone painted OEM rims? SouthernboyWJ ZJ Grand Cherokee Forum 5 02-20-2007 11:16 PM
'04 Grill: painted center part black w/black mesh ~ PIC JCDubya ZJ Grand Cherokee Forum 16 02-10-2007 11:26 PM
