Has anyone had WJ problems when installing oversized tire? - JeepForum.com
post #1 of 11 Old 07-22-2009, 02:03 PM Thread Starter
crashcraddock
The Jeep dealer told me today that some people have tranny problems when installing oversized tires. I don't remember if my torque converter started acting up before or after the tire switch, I think it was after. The mechanic that updated my pcm and tcm told the service advisor that his Jeep acted up after he installed larger tires. So has anyone else had this problem, or do you all for chips?
crashcraddock is offline
post #2 of 11 Old 07-22-2009, 02:36 PM
comptiger5000
I don't exactly believe it. My mother's WJ 4.0 did need a tranny rebuild at about 75k, but I think it was more from neglect than the 245/70/16 A/Ts it's worn for most of it's life.
comptiger5000 is offline
post #3 of 11 Old 07-22-2009, 03:08 PM Thread Starter
crashcraddock
Now the tranny shop is saying he doesn't think the tranny is bad, but something engine related e.i. senors or something. Who knows, I'll find out more tomorrow.
post #4 of 11 Old 07-22-2009, 03:09 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Yeah the bigger tires will be harder on the transmission, axles, engine, transfercase, u-joints, etc...
The 4.0L doesn't have a strong transmission behind it in the first place. Not sure which engine you have.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #5 of 11 Old 07-22-2009, 03:13 PM Thread Starter
crashcraddock
I have the 4.7 with the 45rfe tranny (good stuff), but the Jeep dealer was refering to speed sensors and stuff. I think he was getting me confused with a newer Jeep(my sister's WK).
post #6 of 11 Old 07-22-2009, 07:10 PM
herrmy
I believe it's a 545RFE behind the 4.7.
ROLL TIDE!!!
2002 Grand Cherokee 4.7 HO
3" IRO Coils, MX6's, JKS Adj Trackbar, Rancho SS, KOR Dual SS, Addco rear, BBK 70mm TB, K&N CAI, Magnaflow catback w/ high flow cat and 265/75 M/T MTZ's on 16" M/T Classic II's
herrmy is offline
post #7 of 11 Old 07-22-2009, 09:07 PM Thread Starter
crashcraddock
Not in the 99 and 00s. And maybe even some 01s
post #8 of 11 Old 07-22-2009, 10:09 PM
herrmy
Whoops your right!
ROLL TIDE!!!
herrmy is offline
post #9 of 11 Old 10-05-2009, 05:43 PM
rgbourne2004
Tranny Problems
I have a 2005 Jeep Wrangler with a 4.0 I6 and auto tranny. I havent had any trouble with the transmission until i changed the tire size. I went from the factory tires to **** cepek 17R35 Mudders. Now when the trans gets warm it doesnt want to shift down to 1st. No problem in reverse or higher gears. At times if i accelerate strongly it feels at if the trans slips out of gear and after my rpms and trans pressure lowers it starts to pull again. Dont know if this helps, but i havent narrowed the problem, if you have please let me know. Thanks.http://www.jeepforum.com/ubb/confused.gif
rgbourne2004 is offline
post #10 of 11 Old 10-22-2009, 05:02 PM
jeepers99
bought my 99 jeep wj 4.0 at 90k miles. already had larger tires on(the largest that would fit with stock suspension. minor rubbing) Rebuilt tranny at 130k because reverse went out (partially my fault). Leaky transfer case caused the fluid to get low and the gears to slip. did not know for about a week. About 2 weeks after i changed the seal, I gassed it in reverse while against a high curb. The shop who rebuilt the tranny installed an aftermarket tranny cooler. has worked good since. now at about 145k
jeepers99 is offline
post #11 of 11 Old 10-25-2009, 05:02 PM
SENECA
SENECA's Avatar
My WJ has never been better after the IRO 6.5 lift and slightly larger than stock 32" tires.
SENECA is offline
How to figure out tire pressure on oversized tires? aaron7 ZJ Grand Cherokee Forum 26 03-19-2010 09:55 AM
Roof top carrier for an oversized spare tire marathon mark WK Grand Cherokee & XK Commander Forum 15 12-07-2009 06:55 PM
spare tire well size (Oversized tires) marathon mark WK Grand Cherokee & XK Commander Forum 10 02-26-2009 12:27 PM
Just got done installing my 4.5" f>r lift i have sway bar problems. bjl95mustang ZJ Grand Cherokee Forum 4 06-13-2007 01:15 PM
Problems after installing new engine.....Need help ASAP, going to Tahoe this week chriso ZJ Grand Cherokee Forum 4 02-01-2007 03:39 AM
