Halogen Reverse Light Mod - JeepForum.com
post #1 of 24 Old 09-05-2012, 09:45 PM Thread Starter
dnuccio
Ever out on the trail at night and need to back up, but you can't see where you're going? Then this mod is for you!
Materials:
I used the clear lense halogen lamps from Harbor Freight because they are cheap ($9.99) and they are low profile so they dont block the turn signal.
Electrical ring connectors
Bolts for the connectors
First open your tailgate. Then locate the 3 bolts that hold in the taillight assembly, there are 2 on the side and 1 on top. Remove them and remove the tail light assembly. Remove all the lights from the tail light lense by twisting and pulling the sockets. Find the reverse light, it will have a black wire and a brown wire with green tracer.
Cut the brown wire and install ring connectors on both ends (optional to put one on the bulb socket end, I did in case I ever want to return the reverse lights to stock)
Now attach a ring connector to another piece of wire, this will go to the positive on your light.
Attach a ring connector to the ground wire from your light. I had to extend mine so I used a butt splice:
I decided to ground the lights to one of the bolts that holds the tail light on.
This is what you should have at this point:
Next, drill a hole in your bumper for the light to mount in. Make sure the tail gate can open and close with the light in this position, I had to re-drill once because I forgot this.
Depending on how your light mounts, you may have to remove the bumper cover and access the bolt from the bottom. I was able to stick a rachet in between the bumper cover and the body and tighten the bolt up.
Thats it!
If you have any questions or comments, feel free to post in this thread or PM me. Happy Wrenching!
EDIT: Forgot to mention, you have to take out the original reverse light bulb, because if you leave it in, the circuit draws too much power and blows the fuse. Not to mention it will dim both lights greatly.
dnuccio is offline
post #2 of 24 Old 09-05-2012, 10:00 PM
Airborn
Just curious, can you take a picture close up and lights off?
1998 Jeep Grand Cherokee Laredo 4.0L : 172,xxx miles, IRO 3.5" F>R lift, IRO Adjustable Control Arms, IRO Adjustable Track Bars, 31" Goodyear Wrangler Authority on Cragar V5's, Pavement Pounder until I get out of college :( ...Built Not Bought #650
Spend the Time and the Money the 1st Time, You'll End Up Doing it Anyway.
Airborn is offline
post #3 of 24 Old 09-05-2012, 10:11 PM
zander21510
Thats pretty awesome. Love the MS Paint diagrams lol!
Honestly I dunno why they don't have bright reverse lights standard on all vehicles...it sure would help at night backing out of a parking lot with dozens of college morons on their phones not paying attention to people backing out...
zander21510 is offline
post #4 of 24 Old 09-05-2012, 10:37 PM Thread Starter
dnuccio
yes sir I will take one tomorrow when its light out
dnuccio is offline
post #5 of 24 Old 09-05-2012, 10:43 PM Thread Starter
dnuccio
Thanks! They probably dont do it factory because of cost. Even though they could probably get decent lights for like $5 more, say you make 500,000 cars, you saved alot of money
dnuccio is offline
post #6 of 24 Old 09-06-2012, 12:19 AM
phbrown
1994 ZJ
Thanks! cause that was going to be my question also
needless to say but subscribing now
1994 Jeep Grand Cherokee Laredo| stock| 231 transfer case| 4.0L
phbrown is offline
post #7 of 24 Old 09-06-2012, 08:18 AM Thread Starter
dnuccio
Went out and took some pictures.
Here is the light mounted:
Here is the ground connection, you can just barely see the blue end from the connector:
Here is the ground connector unbolted:
And here is the positive connection, it is the blue cluster with electrical tape around it. The white wire is the positive wire to the halogen light:
dnuccio is offline
post #8 of 24 Old 09-06-2012, 08:51 AM
KoreaZJ
1994 ZJ
...They probably dont do it factory because of cost...
Change housings...
Some ZG (Europe models) have rear fog lamps in the bottom of the housing.
KoreaZJ is offline
post #9 of 24 Old 09-06-2012, 08:59 AM
melk
The rear backup lights from an Aurora fit perfectly in the space next to the license plate. I'm gonna do this at some point.
melk is offline
post #10 of 24 Old 09-06-2012, 09:32 AM
96zedjay
I just replaced my stock bulbs with H3's...... A little more custom fab work for the sockets but results are nice....I'm not big on hanging dung on when a simple mod will suffice.
96zedjay is offline
post #11 of 24 Old 09-06-2012, 09:41 AM
KoreaZJ
1994 ZJ
Nice idea... got pics?
KoreaZJ is offline
post #12 of 24 Old 09-06-2012, 11:06 AM
Bigdjs123
Anyone ever try those "line of fire" led strips they put on trucks. The few I've seen are pretty bright web in reverse
Bigdjs123 is offline
post #13 of 24 Old 09-06-2012, 11:21 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Lol,Korea dont throw those up there unless you gonna give the part numbers too cause I couldn't find one.
Originally Posted by HighLonesome
coralman is offline
post #14 of 24 Old 09-06-2012, 11:33 AM
gothchick
Nice thread. Love the idea of better light out back. I did the PIAA rear aux kit.
Before I get razzed, a new exhaust is on the list soon. Lol. :-)
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
post #15 of 24 Old 09-06-2012, 12:07 PM
96zedjay
Next time I need to replace a bulb I shoot some or maybe when I do #2 jeep I'll do a "How to" write up.
96zedjay is offline
Reverse light circuit coltman151 ZJ Grand Cherokee Forum 1 06-11-2012 12:33 PM
Reverse light....?! BenHinz27 ZJ Grand Cherokee Forum 0 12-13-2011 12:35 PM
Reverse light woes WarBaby ZJ Grand Cherokee Forum 4 12-20-2009 09:32 AM
Reverse light problem gcl1998 ZJ Grand Cherokee Forum 2 09-22-2008 02:02 PM
Reverse light switch? 1RadCJ5 ZJ Grand Cherokee Forum 4 05-21-2007 07:54 AM
