Had a starting issue, fixed it but how to prevent it from happening again? - JeepForum.com
post #1 of 11 Old 06-04-2012, 09:34 AM Thread Starter
mightymurph
My ZJ was starting fine every day, no delay or struggle in the starter at all. I bought a new battery for it with 875 CCA installed it and it started up just fine as I thought it would.
The next day I tried firing it up and the starter wouldn't crank at all. Head lights came on, wipers worked and the fuel pump worked. I figured it was a bad starter motor relay so I switched it with my intermittent wiper relay and nothing, then switched it with my fuel pump relay and again nothing.
So I did a bit of reading and found that some people would arch(?) the 2 ends of the starer with the metal end of a screw driver and listen for the starter to turn. I tried that but I couldn't get a spark, I then tried bashing the starter with a hammer and by accident arched the 2 ends and heard the starter turn. So I figured well might as well try starting it now and it started just fine! So I shut it off and tried starting it a few more times and it starts fine every time.
So what the hell went wrong? :S
mightymurph is offline
post #2 of 11 Old 06-04-2012, 05:35 PM
Oldfrog
2007 WK
Which engine? ( please fill out your Jeep info on your profile)
I would start with looking at the connections. ( duh....I know....but it's a fact).
Your starter might be getting ready to "go" and never come back.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 11 Old 06-04-2012, 05:51 PM
savannahzj
Replace the starter. If you hit it with a hammer and it turned, it is going /gone. I carried a hammer with me for a week waiting on my new one.
savannahzj is offline
post #4 of 11 Old 06-04-2012, 05:56 PM
5-90
5-90's Avatar
1988 XJ Cherokee
You have a "flat spot" in the starter motor - which is why smacking it with a hammer makes it work (impact will usually "get the starter off of the flat spot.")
It's a fairly common problem with intermittently used electric motors as they age - same thing happens with electric fans. Didn't you ever have a house fan that wouldn't start turning when you turned it on, but would go fine if you spun the blades a bit with a pencil? I have.
1) Carry a mallet (rubber, rawhide, wood, leather - not metal!) while you're waiting for the replacement to show up.
2) Bear in mind that, generally, the starter motor is mounted with 1x3/8"x16 screw and 1xM10-1.5 screw. Don't mix them up - keep track of which one goes where!
And the word you were looking for is "arc" - and "arch" is a structural or architectural design principle, often used to support a great weight. An "arc" is an electrical discharge, either through open air or through a conductor that isn't normally supposed to carry current...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #5 of 11 Old 06-04-2012, 06:54 PM
KJK
The solonoid contacts are going bad. You either need to replace the starter or get a kit online to replace the contacts (it's really easy).
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #6 of 11 Old 06-04-2012, 10:00 PM Thread Starter
mightymurph
Thanks for the awesome reply's! I'm going to order a new starter motor from rock auto ASAP.
I see that they have some refurbs, but I'd rather buy one that's all new. They carry brands such as TYC, PURE ENERGY, ACDELCO and REMY. Anyone have any experience with these brands and can tell me which is best?
post #7 of 11 Old 06-04-2012, 10:06 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I'd like to help with which brand I bought, I don't remember. However, I think it was the AC Delco brand.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #8 of 11 Old 06-04-2012, 10:38 PM
5-90
5-90's Avatar
1988 XJ Cherokee
ACDelco and Delco-Remy are made in the same factories - as I recall, the ACD is the new stuff and the D-R is the remanufactured. Both are good, in my experience.
5-90 is offline
post #9 of 11 Old 06-05-2012, 11:12 AM
greyhnd
I once worked in a parts store that did alt, starter, gen rebuilds for mining equipment. I remember the mechanics like the Delco parts because they were the easiest to repair. You'll pay a bit more for the AC Delco or Delco-Remy but you'll have less problems in the future.
greyhnd is offline
post #10 of 11 Old 06-05-2012, 02:09 PM
coltman151
X2 on starter going bad, carrying a hammer, and Delco.
Having a hammer in your vehicle is good practice anyway.
95 Laredo 4.0, 2" RE BB, RC N2.0 Shocks, Custom Roof-Mount Light Bar w/ 6 lights, Bumpers deleted, Homemade sway bar discos, Michelin LTX 31x10.50s, and a Dog Box :)
Planned: Homemade Spare tire carrier, double shear front track bar, 4 adjustable rear control arms, New Rims and 33" Wrangler MT/Rs or BFG M/T KO's w/ LOTS of trimming.
coltman151 is offline
post #11 of 11 Old 06-05-2012, 06:29 PM Thread Starter
mightymurph
Right on! Delco it is. Thanks for the responses, cheers!
Starting issue Thunderhawk ZJ Grand Cherokee Forum 0 11-26-2011 05:40 PM
Starting Issue BigLebowski ZJ Grand Cherokee Forum 9 10-30-2010 11:44 PM
Finally fixed stalling and fuel pump issue! GaJeepDriver ZJ Grand Cherokee Forum 1 08-18-2010 06:14 PM
starting issue 94redlerado ZJ Grand Cherokee Forum 1 07-14-2010 08:10 PM
01 WJ starting issue stew930 ZJ Grand Cherokee Forum 0 12-30-2008 10:53 AM
