Ground under ignition coil. - JeepForum.com
post #1 of 12 Old 01-31-2013, 10:41 AM Thread Starter
JeepinJordan
Passenger side, on the block under the ignition coil, there are pigtails connected to what looks like a ground point. I messed with the connectors when the jeep was running and it would stall out. Is this an important ground point??
JeepinJordan is offline
post #2 of 12 Old 01-31-2013, 10:42 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Its the engine harness ground. Uber important.
HighLonesome is online now
post #3 of 12 Old 01-31-2013, 12:07 PM Thread Starter
JeepinJordan
It should not stall when I play with it right? What should I do? Stalls or cuts out when driving then jumps back on, already changed CPS with a mopar sensor. Idk how this would cause it to stall when driving. Its giving ignition and misfire codes.
-Bone stock 1996 Jeep Grand Cherokee Laredo 4.0L
post #4 of 12 Old 01-31-2013, 01:13 PM
bananaslug
Clean the connection and block, then put it back on
bananaslug is offline
post #5 of 12 Old 01-31-2013, 01:14 PM
HighLonesome
Yes it will cause a stall. Repair it properly and you're golden.
post #6 of 12 Old 01-31-2013, 01:27 PM
DirtDodd
x2
Nothin is no good with no good grounds! (What a negative statement...)
yes, my attempt at a polarity pun
DirtDodd is offline
post #7 of 12 Old 01-31-2013, 01:40 PM
HighLonesome
The connector probably needs repaired. That's what happened to mine. I soldered it up.
post #8 of 12 Old 01-31-2013, 02:16 PM Thread Starter
JeepinJordan
I will clean it but I hope that it doesn't turn out to be like this. It cut out bad today after messing with it.
post #9 of 12 Old 01-31-2013, 03:07 PM
HighLonesome
Mine broke off completely. Caused by an engine swap and not putting the harness back exactly like it was. That ground cable was stretched and it eventually snapped. Make sure there's no tension on it. In other words, the cable should be relaxed. Its really an easy fix once you diagnose it.
post #10 of 12 Old 02-01-2013, 04:46 AM
KoreaZJ
1994 ZJ
Very important grounds...
Small BK and BK/OR wires are for Data Link Connector. Large BK wire is Generator GROUND. Two BK/TN wires are GROUND for the PCM. Better not to "test" them with power on, you might damage the PCM. Disconnect the battery, remove the lugs, clean everything well, reassemble tightly.
KoreaZJ is offline
post #11 of 12 Old 02-01-2013, 03:06 PM Thread Starter
JeepinJordan
Cleaned these. Did not do a thing, still dies out and has code 43! Ugh. Accell coil, cap & rotor, spark plug and wires all new.
post #12 of 12 Old 02-01-2013, 06:36 PM
ZeeJay1997
Korea gave you good advice, did you take it apart and clean everything?
Does it still stall when you mess around with the ground wire?
ZeeJay1997 is offline
