Ground Locations - JeepForum.com
post #1 of 4 Old 06-24-2004, 01:38 PM Thread Starter
buzzbomb
Ground Locations
Can anyone tell me where the grounds on a '96 GC limited with a 4.0 and auto are? I'm having electrical gremlins including pegged temp guage, automatic lights always on, no center dash lights, and no steering wheel radio controls. TIA
buzzbomb is offline
post #2 of 4 Old 06-24-2004, 07:12 PM
driabyor
driabyor's Avatar
1994 ZJ
I think that there are some braid wires on the back side of the engine that run to the fire wall ..
you might also check al the connectors to make sure that they are together. and if your are feeling brave take them apart to check to see if they are corroded...
my 86 ford truck was acting up.
wasnt running right .. what I did for it was to run a new ground wire from the battery to the engine block that solved that problem..
driabyor is offline
post #3 of 4 Old 06-05-2013, 10:02 AM
Deaconblu
1995 XJ Cherokee
There is a thing called bcu body control unit will cuase those gremlins. ecu willtoo
Deaconblu is offline
post #4 of 4 Old 06-05-2013, 05:22 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Instrument panel ground is in the floor pan behind the drivers seat. Korea Zj is the electrical wizard here.
Originally Posted by HighLonesome
coralman is offline
switch locations RKOTAREK ZJ Grand Cherokee Forum 0 02-07-2010 06:27 PM
CB mounting locations? ltdanyj WK Grand Cherokee & XK Commander Forum 9 05-05-2008 02:20 PM
PCM sensor ground against global ground Godzilla_janus ZJ Grand Cherokee Forum 7 11-25-2007 03:10 AM
WJ switch locations devile ZJ Grand Cherokee Forum 7 11-28-2006 11:15 PM
Winch Locations Death-Mobile ZJ Grand Cherokee Forum 5 08-08-2004 09:03 PM
