So I have a noise that is being stubborn to track down. I had thought it was the LH hub or ujoint...replaced both and noise remains. It's not tire rub as the tires are factory size and it has wheel spacers on it from bigger tires the previous owner had on the Jeep. The noise goes away after driving straight again for a few seconds. Front end seems fine as there are a couple new parts and everything else seems tight. Here's the list of relevant things I've done since July when I bought this Jeep
-full tuneup plugs,wires,cap & rotor, coil
-trans service
-front & rear diff service with Lucas and additive in the rear diff
-new pads and rotors all around
-fixed a couple oil leaks...filter adapter and valve cover gasket
-good set of used tires
-alignment after front end work
Any ideas? I had thought maybe motor mounts but they seem ok
-trans service
