grinding/rattle noise when passing gear is engaged??? - JeepForum.com
post #1 of 6 Old 02-28-2012, 09:20 PM Thread Starter
westcoastvibes
I have notice 2 or 3 times now a grinding/rattle sound when I kick the tranny into passing gear. My first response was "hell, the tranny is going" but after the 2nd and 3rd time hearing it, it sounds like its in the dash or possibly on the firewall. I dont know if this makes sense but it sounds like the rapid clicking a starter or relay would make with insufficient voltage, just much faster.
westcoastvibes is offline
post #2 of 6 Old 02-29-2012, 08:57 PM Thread Starter
westcoastvibes
Nothing??? no body has any idea???
post #3 of 6 Old 02-29-2012, 09:49 PM
fitzerfamily
I have same problem sound like mine is from the engine once rpms get high.
fitzerfamily is offline
post #4 of 6 Old 02-29-2012, 10:46 PM
PolkaPower
The v8's suffer from a ping or detonation when the plenum gasket goes bad. If you dump a bottle of octane booster in there and it goes away then you know for sure it's coming from the motor. I don't know about the 4.0.
PolkaPower is offline
post #5 of 6 Old 03-01-2012, 07:57 AM Thread Starter
westcoastvibes
I have narrowed it down to something passing gear related. It does not do it with just high engine RPM's, its only when the tranny kicks into the passing gear. Like I said though, it does not sound like a metal grinding but more of a electrical grinding if that makes sense. If anyone has ever heard a commercial AC unit kick on or a older refrigerator when it first starts operating, thats similar to what I am hearing.
post #6 of 6 Old 03-01-2012, 09:51 AM
PolkaPower
Maybe you have a loose fuel line or a linkage that is rattling. Possible heat shield rattle.
grinding noise when shifting into gear iabonir WK Grand Cherokee & XK Commander Forum 1 05-19-2012 12:16 AM
Having an odd passing gear problem Midnightluckey ZJ Grand Cherokee Forum 6 11-21-2011 09:57 PM
4.0 passing gear 93zjgrand ZJ Grand Cherokee Forum 4 02-28-2011 06:49 PM
Hesitation above 70 in passing gear indianajeep ZJ Grand Cherokee Forum 5 05-14-2009 07:15 PM
Whinning when in passing gear wjjeepgirl ZJ Grand Cherokee Forum 6 10-20-2005 04:56 PM
