Grinding noise (output bearing?) - JeepForum.com
post #1 of 3 Old 10-20-2011, 05:17 PM Thread Starter
ccoston
I am experiencing a grinding noise that is getting louder lately. I get it for a second or so immediately upon letting off the gas. It sounds like it is coming from mid-vehicle and not the rear, and it shouldn't be anything in the rear diff because I just had it rebuilt at 4wheelparts a couple months back.
I initially thought it could be the drive shaft u-joints, so I replaced those. Didn't solve the problem. Does the problem sound like the rear output bearing on the TC? I have a 249, and the Jeep came with no front driveshaft, so I've been running without for now. It's a 98 5.2L.
ccoston is offline
post #2 of 3 Old 10-20-2011, 09:41 PM
SMGORDON1259
From What I have learned, NEVER DRIVE YOUR JEEP AWD WITHOUT THE FRONT DRIVE SHAFT
The issue may be the Viscus coupler inside the transfercase ( 249)
The VC senses Wheel slippage and transfers power to the wheels that is not slipping Without the front drive shaft the VC is working full time and most likely "burning up".
not sure how true this is But I have heard it many times.
does your Front Differential have a U joint Yoke Or a pancake Style with 8 bolt holes?
gonna cost to rebuild the TC or replace it I have an extra working one and an extra drive shaft without the CV joint on the front.
The Drive shaft cv joints go for about 160 to 196 dollars depending on where you get one. O'reillys has one for 196 with lifetime warranty
1995 Jeep Grand Cherokee Laredo 5.2 v8 magnum, Dana30/35, TC NP-249, Trans 46rh 170,000miles
SMGORDON1259 is offline
post #3 of 3 Old 10-20-2011, 09:52 PM
PolkaPower
He has a 96 or later. It's fine to pull the front DS. It's on the 93 to 95 that you can't.
93-95 split torque 50-50
96-98 split torque 90-10
PolkaPower is online now
242 front output shaft bearing kinkula ZJ Grand Cherokee Forum 3 06-09-2010 02:48 PM
NP249 Output Bearing Replacement MAO ZJ Grand Cherokee Forum 8 04-12-2010 05:47 PM
93 GC output shaft bearing 93_GrandCheroke ZJ Grand Cherokee Forum 4 09-12-2009 08:41 PM
247 Rear Output Bearing Replacement Granam73 ZJ Grand Cherokee Forum 2 01-02-2009 08:54 PM
NP249 Rear Output Bearing R&R vol96 ZJ Grand Cherokee Forum 6 06-04-2005 08:36 AM
