grinding noise from front end - JeepForum.com
post #1 of 4 Old 02-23-2008, 09:45 PM Thread Starter
ryan-5.2zj
hello, my 98 grand has developed some sort of squealing or grinding noise. it isn't similar to a fan belt squeal. the whole thing us to come and go, mostly uphills but now it's constant. the noise is noticeable when i start rolling around 30 mph or more. the noise comes with the use of the gas pedal and fades away as soon as i release the pedal. I jacked up the front end and spun the tires and heard nothing. my AC pulley always squeaks, but this has a vibration of it's own. any ideas on what i could be looking at?
ryan-5.2zj is offline
post #2 of 4 Old 02-23-2008, 10:13 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
driveshaft u-joints most likely. check for play in the shaft. if there's any play at all you have a bad joint.
ratmonkey is offline
post #3 of 4 Old 02-24-2008, 11:33 AM
Vestjam
I'd take at look at the u joints also. Wheel bearing hubs will usually growl before they squeal... no comment!
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
post #4 of 4 Old 02-24-2008, 02:26 PM Thread Starter
ryan-5.2zj
thanks for the u joint tip. i have some wiggle in the front shaft coming from the TC area.
ok next question, should i replace just the u joints or could the yoke be bad also? thanks again for the help
Front End Grinding Noise..I know this has been asked, please look. boosoo ZJ Grand Cherokee Forum 4 07-12-2012 09:16 PM
grinding noise from up front leofanti ZJ Grand Cherokee Forum 6 08-03-2009 06:03 PM
Help w/ front end grinding noise harlow00 ZJ Grand Cherokee Forum 0 02-05-2008 07:50 AM
Grinding Noise From Front End parnell5150 ZJ Grand Cherokee Forum 16 04-10-2007 10:14 AM
Help! What is this grinding noise from front end.. 7tiger7 ZJ Grand Cherokee Forum 4 02-17-2007 06:19 PM
