grinding noise during acceleration - JeepForum.com
post #1 of 14 Old 09-03-2008, 12:17 PM Thread Starter
phoenixcherokee
My parents started having a problem with their Jeep a few months ago. While accelerating there is a grinding noise that happens right around 45mph. There is no noise before that or after you get past 45mph. I have not been in the vehicle while it happens so I don't have first hand knowloedge they only described it as a grinding noise though they said was really loud and can be accompanied by a bang as well.
Any ideas what might be causing this?
The vehicle is a 93 Grand Cherokee Limited (5.2L), Auto Tranny.
*edit
The grinding noise is coming from under the vehicle.
phoenixcherokee is offline
post #2 of 14 Old 09-03-2008, 10:56 PM Thread Starter
phoenixcherokee
Any ideas?
post #3 of 14 Old 09-03-2008, 10:59 PM
SnowdogMarc
I had a similar noise in my Silverado. It was the front wheel bearing and CV joint.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #4 of 14 Old 09-03-2008, 11:55 PM
volley13
Grinding Noise
I hope you get some answers; I'm having the same issue with my '96 GC Laredo.
volley13 is offline
post #5 of 14 Old 09-14-2008, 03:51 PM Thread Starter
phoenixcherokee
I was able to road test the Jeep today. It doesn't matter what speed the Jeep is going there is a ticking/grinding noise coming from under the vehicle when you accelerate quickly in any gear. If I take it real easy I don't hear the noise but if I get on the pedal at all I hear it. The noise is coming from the middle/ front of the vehicle.
I also hear the noise if I have the Jeep sitting still and put the transfer case in neutral and the tranny in neutral.
Any ideas what could be causing this?
post #6 of 14 Old 09-14-2008, 07:41 PM
WhiteOut
WhiteOut's Avatar
Are you sure its coming from under the Jeep and not from the engine? If the tranny and tcase are both in N at idle it seems like the sound is most likely coming from the engine.
WhiteOut is offline
post #7 of 14 Old 09-14-2008, 09:42 PM Thread Starter
phoenixcherokee
I'm not 100% but its weird that it doesnt make that noise if the Jeep is in park, and has all wheel drive engaged.
post #8 of 14 Old 09-29-2008, 12:08 AM
MeWJWifeZJ
Check the exhaust shields. they come loose with age
MeWJWifeZJ is offline
post #9 of 14 Old 09-29-2008, 12:43 AM
Black98ZJ
not sure if this helps any, but my catalytic converter is going, and before i diagnosed it as that, i thought the transmission was screwed up, mines did make a grinding noise (like a rattle..grind..rattle...grind) around 40-55 mph, and would go away around cruising speed 60mph.. but mines isn't followed by a bang.. i'll make a video if it helps when i get the chance this week.
08 Grand Cherokee WK
5.7 HEMI
98 Grand Cherokee ZJ
4.0 Stock (First Jeep)
Black98ZJ is offline
post #10 of 14 Old 09-06-2010, 04:18 PM
Incursorio
Same here;
I have exactly the same problem .. When I start from the stop, I hear a "kick" and after that, ONLY when starting on hills, I hear chirping sound from somewhere under my jeep.. .
It can be heard only when pressing accel. pedal on hills going upwards, never downwards..
What could that be? It's a 1995 YJ, TF999 auto and 4.0L HO engine..
Here's a video of the sound:
(tire burning was UNINTENTIONAL!)
YouTube - JEEP YJ - Strange noise in rear differential
You can follow me.. but it's gonna hurt
www.wettpunktracing.com
Incursorio is offline
post #11 of 14 Old 09-06-2010, 04:23 PM
Billy
Billy's Avatar
U joint could be shot. 45mph could be the point where the frequency of the bad u joint meets the natural frequency of the vehicle causing the grinding. Of course you would be feeling it too. Not just hearing it.
Everyone IS out to get you, if you just believe in yourself and try hard enough!
Billy is offline
post #12 of 14 Old 09-06-2010, 04:29 PM
Incursorio
I'm not feeling a major vibration.. Just that godawful sound
post #13 of 14 Old 09-06-2010, 04:54 PM
Billy
Billy's Avatar
Bearings perhaps?
Billy is offline
post #14 of 14 Old 09-07-2010, 03:38 AM
Incursorio
I don't know really.. I will try and see if something rubs
This is the sound when accelerating from full stop:
Sound clip(03).amr
Sound clip(04).amr
What Would Cause a Tapping Noise Under Acceleration? JayIV ZJ Grand Cherokee Forum 20 10-02-2013 01:27 PM
Grinding noise in acceleration fireman33 ZJ Grand Cherokee Forum 13 12-08-2010 11:46 AM
Vibration/Grinding under acceleration MidniteSquirrel ZJ Grand Cherokee Forum 11 04-24-2008 11:12 AM
Clunking Noise under acceleration? gohser ZJ Grand Cherokee Forum 7 02-11-2006 12:44 PM
grinding noise only on acceleration josephmartins ZJ Grand Cherokee Forum 5 09-13-2005 06:46 AM
