Grinding noise in 4-Lo only when put in gear? - Page 2 - JeepForum.com
post #16 of 21 Old 09-18-2012, 05:31 AM
newfieZJ
I hate the sound of the case grinding . I always get on a slight incline , shut the jeep off , switch gears , and go again . No strain on the linkage , no grinding of gears
newfieZJ is offline
post #17 of 21 Old 09-18-2012, 11:42 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
What does shutting it off do that neutral doesn't? ;-)
ratmonkey is offline
post #18 of 21 Old 09-18-2012, 11:43 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Originally Posted by 95grandorvis View Post
I never put mine in nuetral? Im always rolling in drive and pull it in low, otherwise it grinds.
That's not right, it should grind horribly trying to shift it in drive.
post #19 of 21 Old 09-18-2012, 12:02 PM
95grandorvis
Its always been like that. My buddys jeep is the same way too. Either way its nice to be able to switch on the fly if i need to
95grandorvis is offline
post #20 of 21 Old 09-18-2012, 03:25 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
the mechanics of how gear reduction works in these cases say you shouldn't be able to shift into low at all while still in drive.
post #21 of 21 Old 09-18-2012, 03:32 PM
95grandorvis
I get what your saying but thats how it works lol. Ive always done it like that
4low , transfer case , transmission
grinding noise when shifting into gear iabonir WK Grand Cherokee & XK Commander Forum 1 05-19-2012 12:16 AM
grinding/rattle noise when passing gear is engaged??? westcoastvibes ZJ Grand Cherokee Forum 5 03-01-2012 09:51 AM
zj 5.2 grinding noise? blackwhiteriot ZJ Grand Cherokee Forum 1 07-18-2009 06:05 PM
grinding noise Jones ZJ Grand Cherokee Forum 9 05-21-2008 04:44 PM
Grinding noise CLNinja ZJ Grand Cherokee Forum 11 02-25-2008 10:30 AM
