Greetings from Australia - JeepForum.com
post #1 of 8 Old 01-05-2015, 04:40 PM Thread Starter
ZGRay
Happy New Year.
I'm hoping for some advice please.
I'm attempting to prepare my ZJ ( known as ZG down under ) for a week of touring/camping in the Aussie Bush. She hasn't seen much use for a while now, its had a whine from somewhere in the drive line which has progressed to include a light thump when under load driving straight ahead. The noise changes to a loud clunk during tight turns.
I suspect the Rzeppa joint in the front drive shaft is the problem.
Mine has the 249 Transfer Case with a double cardon at the TC and Rzeppa at the front diff.
I have removed the front drive shaft, drives real smooth without it, no whine or clunks and bangs. Inspected drive shaft, all looks OK to the untrained eye.
Last time out left side CV axle started to "twang" when pushed hard, replaced both front axles/CVs.
So far I have:
Checked for movement in relevant components.
Changed both diff oils, no signs of metal, both appear OK to the untrained eye, couldn't see any pitting/scoring etc.
Changed TC oil, came out clean.
I've turned front diff by hand, smooth and easy, noticeable backlash, guessing that's normal.
I could not turn TC by hand with it and transmission in neutral, drive shaft removed, is this normal?
Could the viscous coupling in the Transfer Case be the culprit?
Can someone point me in the right direction please.
Cheers
Ray
ZGRay is offline
post #2 of 8 Old 01-06-2015, 10:54 PM
1998_ZJltd
Sounds like the VC in the t case ....
Lots of write ups on it here ..... no real hard but cost a little coin to do ....
1998_ZJltd is offline
post #3 of 8 Old 01-06-2015, 11:03 PM
kg6mov
Hears the voices
kg6mov's Avatar
Which year do you have?
The 249 always links the driveshafts even in neutral. Did you have both shafts removed when you tried to spin it?
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ 5.9 - Junked
kg6mov is offline
post #4 of 8 Old 01-07-2015, 05:28 PM Thread Starter
ZGRay
Hello again,
Thanks for the responses, it's a July '96 build 6cyl.
I have only removed front drive shaft so far, so if I remove rear shaft next weekend and it still won't rotate, would I be correct in assuming it's the transfer case?
Cheers
Ray
ZGRay is offline
post #5 of 8 Old 01-07-2015, 05:35 PM
kg6mov
Hears the voices
kg6mov's Avatar
That would be one hell of a bad day, but yes. If you remove both shafts the t-case outputs should spin freely together. You can also lift one rear tire with a jack and spin that to spin the rear shaft and thereby the front t-case output.
kg6mov is offline
post #6 of 8 Old 01-08-2015, 12:13 AM
siguy
hello downunder
siguy is offline
post #7 of 8 Old 01-08-2015, 10:46 PM
nicyousuckk
Australian... why are you into ZJ's when you all have the most awesome looking outback ute things?!
nicyousuckk is offline
post #8 of 8 Old 01-08-2015, 10:51 PM
SchizophrenicMC
There's a reason they're called GRAND Cherokees.
1997 Grand Cherokee Orvis Edition
FUEL ECONOMY IS FOR LOSERS
SchizophrenicMC is offline
