Great info on 93-98 GCs - JeepForum.com
post #1 of 2 Old 01-01-2003, 02:13 PM Thread Starter
JeepGuyRyan
Found this article which solved alot of questions I had regarding the differences between the 93-98 GC, I recomend everyone read it.
http://www.edmunds.com/reviews/gener...8/article.html
-=Ryan=-
JeepGuyRyan is offline
post #2 of 2 Old 01-02-2003, 12:15 AM
MJR
MJR's Avatar
1988
Re: Great info on 93-98 GCs
Pretty good. Here is the only problem.
Edmunds
Joining Selec-Trac and Quadra-Trac is Quadra-Drive
99-up are Quadra Trac II (NV 247) whereas the 93-98 are Quadra Trac (NV 249).
The NV 249 uses a viscous coupler to transfer power to the front and rear driveshafts but never worked very well and could cause the front diff to burn up if all the tires were not the same size.
The NV 247 is the same t-case in the Quadra Drive system which uses a gerotor pump to engage clutches to transfer power to the front and rear driveshafts. Tires sizes should be the same also.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
This Board has Great Info... PWM Relay Redstarlover ZJ Grand Cherokee Forum 1 04-20-2008 07:58 PM
45/545RFE tranny..Great info rxl ZJ Grand Cherokee Forum 3 11-30-2007 11:31 PM
Just great! Yardman Harry ZJ Grand Cherokee Forum 31 11-18-2006 09:25 AM
Help, need info on 4wd, info inside frenchfriedshoe ZJ Grand Cherokee Forum 5 03-11-2006 10:47 PM
Another Great WJ on 33s! Texas ZJ1 ZJ Grand Cherokee Forum 6 03-05-2005 10:18 AM
