Grease Choice & Tune Up? - JeepForum.com
post #1 of 5 Old 04-06-2013, 09:32 AM Thread Starter
BlazerZJ
I am working on doing a full tune up on my 1997 ZJ that I recently purchased. I have the 4.0 with 42RE and NP242. I am planning on changing the fluid in the Tcase along with the transmission. Also going to change the fluid in both differentials and grease the suspension. I had a couple questions about the following. I have the Dana 30 front differential and the Dana 35C with Trac-Loc on the rear differential. This jeep is my Daily Driver but I will be taking it mild offroading on occasion but nothing major as of now.
1. The Tcase andTranny both take ATF +4 correct? I'm planning on using the Valvoline ATF +4 synthetic fluid.
2. What differential fluid should I be using in the front and rear differential? Isn't there some additive I should use in the rear differential? Any certain brand of additive?
3. I planned on using Fel-Pro gasket and filter for the Transmission is this good?
4. On the differentials I don't know whether to use Fel-Pro gaskets for differentials or should I use RTV? I will be getting the Lubelocker reusable gaskets if they are worth it but probably not for a little while.
5. My suspension upgrades are in my sig along with Moog ball joints and such and I am undecided as to what grease I should be using for my suspension? I have seen both green and red Mystik, Lucas heavy duty, standard store brand multi-purpose, and heavy duty Moly-Lithium Grease.
Any help would be great! I haven't done this type of work much before which should explain all my noobie questions but I want to make sure I am doing it right and want to take care of my jeep.
Thanks to all the Jeep owners!!!
1997 Jeep ZJ Laredo Prairie Pearl Coat, 4.0L, Selec-Trac NP 242, 3.5" RE Super-Flex Lift, Rustys Trac-Bar, JKS Quicker Discos, 15" Cragar Black "D" Windows, 31x10.5r15 Hankook Dynapro ATM tires,
BlazerZJ is offline
post #2 of 5 Old 04-06-2013, 10:03 AM
JS97ZJ
If you go to Bob the oil guy's website, you can get more info than you could ever use as far as lubs are concerned.
ATF-4 is normal ATF that has been reformulated to to pass Chrysler's standards of synthetic oil, and is not a true synthetic but for all intent it does what it's meant to do.
There is a few companies that do make a pure synthetic but of course charge.
I would recommend using synthetic in the diffs, and if your going to off road or tow, add some wear additive to it.
JS97ZJ is offline
post #3 of 5 Old 04-06-2013, 10:19 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Atf+4 is all synthetic by the official sae definition of synthetic. It is not "just regular atf with some additives ". the additive package, exclusive to atf+4 and not available in bulk separate, is the only thing that matters about it. So you can't just use cheap atf and throw some lubegard in there and expect it to work correctly.
All of the questions you've asked are answered in the FAQ. Except maybe about the grease. Simply buy the most expensive marine rated grease you are willing to pay for. When greasing with a different grease than was originally in there pop the boots up and pump grease through till only the new stuff is coming out.
ratmonkey is offline
post #4 of 5 Old 04-06-2013, 10:37 AM Thread Starter
BlazerZJ
Thank you Ratmonkey, I was able to find most questions to my answers. Only things I couldn't find is whether to use a gasket or Rtv on differentials and if Rtv which one (grey, black, etc). Also didn't find anything about grease but thank you for helping me find most answers.
BlazerZJ is offline
post #5 of 5 Old 04-06-2013, 12:15 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Thats why I answered the grease question.
Use whatever rtv you have. Differentials should be serviced yearly if you wheel.
