Grande Cherokee door latch will not latch - JeepForum.com
post #1 of 15 Old 02-28-2009, 08:32 PM Thread Starter
arory1@shaw.ca
I have a 94 Grande Cherokee Laredo. I just replaced the sagging hinge pins and bushings on the drivers door.
It went fine everything is lined up again however the latching mechanism on the door is stuck down somehow and will not latch over the piece on the pillar.
Does anyone know why or how to fix this.
P.S. the metal on the door was mangled some what. I straightened as best I could and used large washers and the existing screws to hold the mechanism in place in the door(they are not interfering with anything as far as I can tell)
email..arory1@shaw.ca... Thanks...Neil
arory1@shaw.ca is offline
post #2 of 15 Old 02-28-2009, 09:05 PM
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
Post your question here: http://www.jeepforum.com/forum/f13/
This is a forum for the Cherokee, not the Grand Cherokee.
- Justin
1992 Cherokee Laredo - mostly stock, DD. 300k miles and counting
2004 Grand Cherokee Laredo - 4.7, bone stock - Wife's DD
Tru2Chevy is offline
post #3 of 15 Old 03-01-2009, 09:58 AM Thread Starter
arory1@shaw.ca
thanks I would if I could figure out how..sorry..I was lucky enough to figure out how to post it here...Neil
post #4 of 15 Old 03-01-2009, 12:05 PM
Guswut
Follow this link and it will lead you directly to the Start A New Thread area: http://www.jeepforum.com/forum/newth...newthread&f=13. Good luck, and if they can't help try using a bigger hammer!
My Jeep: 1996 Cherokee Country 4.0L A/T 4WD (
My Bike: Suzuki Bandit 1200s (fox rear shock, hotshot stage 1 header, black duct tape * 100!)
Guswut is offline
post #5 of 15 Old 03-01-2009, 01:28 PM
MGrobe
Man In Black
MGrobe's Avatar
Moving to GC forum.
-Marc-
Sweet Pea 1998 - XJ
For Sale: (4) AR 767-5766 Wheels (used) 15x7, 5x4.5, 4.5BS - for local pickup in the Chicago-area
MGrobe is offline
post #6 of 15 Old 03-01-2009, 02:17 PM
liredneck
Were did you get the hinge pins my door sagging realy bad
97 tj 6 cyl 5 SPd 4" supelift 35" baja claws 8.8/hp 30 ,4.10 lockrite in the rear , RR sye and adams dc shaft ,10k lb viper winch and other crap
liredneck is offline
post #7 of 15 Old 03-02-2009, 08:28 AM Thread Starter
arory1@shaw.ca
re sagging doors
Hi thanks for the redirect......got the hinge pins and bushings at NAPA for around $30.
Neil
post #8 of 15 Old 03-02-2009, 09:56 AM
eshew
I was having a paroblem with one of my doors not latching. Got some CRC slicone lube ans sprayed the lock assembly with a bit, there was a small hole by the lock which I also lubed up, problem solved for me.
eshew is offline
post #9 of 15 Old 03-02-2009, 10:20 AM
JeepForever
I had a similar problem on the hood latch. Sometimes a bit of lube helps. Try WD-40 to loosen it up, then once it's working, apply some grease to the parts that touch. Try locking & unlocking, and opening with the latch (use a screwdriver to flip the latch locked & unlocked if you can). Be sure it's "open" when trying to latch it. Maybe the lock is in "closed" (locked) position and can't grab the pin.
JeepForever is offline
post #10 of 15 Old 03-02-2009, 10:54 AM
JeepCreep117
Same here, when it's super cold, like -30C, I have to put WD-40 on the door latches and the hook where it catches. Even then the door sometimes bounces back instead of closing.
1996 5.2L Jeep Grand Cherokee Limited 2006-Present
*First vehicle but not the last Jeep!*
19 year old student with a Haynes
BLACK JEEP SOCIETY
JeepCreep117 is offline
post #11 of 15 Old 03-02-2009, 06:27 PM Thread Starter
arory1@shaw.ca
Hi and thanks again...it seems to be more than a lubrication problem I was really hoping to avoid taking the door apart...I may be able to loosen and adjust, its sitting around zero degrees here and Im using a tie strap to keep the door closed at the moment.
Neil
post #12 of 15 Old 03-10-2009, 08:38 PM Thread Starter
arory1@shaw.ca
thanks for the help everyone..I was able to loosen the three allen head/torx screws on the door and the piece on the pillar enough to make adjustments and everything is working again for $30. and some thought. Oh by the way ...Liredneck...if you dont have a helper to take off and replace the door...try an engine hoist if you dont have one you can rent usually for $25. a day and they fit in a pickup.
Good luck...Neil
post #13 of 15 Old 02-25-2015, 07:30 AM
mikesoldjeep
mikesoldjeep
I have 1995 Jeep Grand Cherokee with damaged innards on my drivers door. Won't close AT ALL and is being held closed with a strap. Found out that this was a common problem and a recall issue right after they were manufactured. Looked into a replacement door but they cost @400-500 dollars plus. I guess I have to begin by tearing the door apart and getting the latch mechanism from "SOMEWHERE"? Boy oh boy....do I need help/advice !!!!
mikesoldjeep is offline
post #14 of 15 Old 02-25-2015, 07:58 AM
jrdoggett
Instead of digging up an old thread, I'd suggest starting your own.
using Jeep Forum app from my couch, or broken down on the side of the road lol
jrdoggett is offline
post #15 of 15 Old 02-25-2015, 09:36 AM
kurtzjreed
Hold the button on the door and use a flat head screw driver to push open the door mechanism with a flat head screw driver worked for me on my 95 zj
kurtzjreed is offline
Broken Door Latch...PLEASE HELP... PIC adgjqetuo ZJ Grand Cherokee Forum 3 11-06-2013 08:57 PM
Door latch repair kit? agtpony ZJ Grand Cherokee Forum 2 11-06-2013 07:04 PM
door latch fixmyjeep ZJ Grand Cherokee Forum 1 07-07-2009 08:57 AM
GC door latch, wont latch arory1@shaw.ca ZJ Grand Cherokee Forum 0 03-02-2009 08:33 AM
WJ door latch fix gpJeep ZJ Grand Cherokee Forum 9 04-11-2007 06:35 PM
