Grand problem - JeepForum.com
post #1 of 18 Old 06-06-2013, 06:40 PM Thread Starter
49WillysPU
I have a 96 JGC with 4.0 and auto trans. About a week ago it died in traffic and had blown a 20 amp mini fuse. I searched the forum as to why it kept blowing the fuse and it led me to check the O2 sensor on the cat. Sure enough the drive shaft had rubbed and exposed the wires. I fixed that. Now it will randomly die. It has symptoms like its out of gas and then dies. I can start it back up and it's usually fine for the trip. It's becoming more frequent. No check engine light comes on. I've read about similar issues traced to the crank shaft sensor. Is this a good place to start. Anyone dealt with this?
49WillysPU is offline
post #2 of 18 Old 06-06-2013, 06:47 PM
eagsc7
1994 ZJ
Yeah.. Crank Shaft Sensor... Have FUN with the Bolt, and removal / Install. I went thru the Cap, Rotor, Wires, Plugs, and even an ign Col and Distributer before the sensor. I'm sure they May have had something to do with it as well. If it Dies Abruptly, its "Usually an Electrical Issue" says my old mechanic...
eagsc7 is offline
post #3 of 18 Old 06-06-2013, 07:02 PM Thread Starter
49WillysPU
I'm tryin not to throw a bunch of money into it locating the problem. This is the fuse that blew. 2nd down mini 20 on the right. Anyone know what it is specifically?
post #4 of 18 Old 06-06-2013, 07:08 PM
ZeeJay1997
PCM and ASD relay
ZeeJay1997 is offline
post #5 of 18 Old 06-07-2013, 01:25 AM
nicholasluke27
Try cleaning your throttle body and TPS
nicholasluke27 is offline
post #6 of 18 Old 06-07-2013, 10:18 AM
PolkaPower
You can't clean a TPS. But you can clean the IAC valve.
PolkaPower is offline
post #7 of 18 Old 06-07-2013, 10:37 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Tap on the IAC, if it causes a stumble or stall, that is a likely culprit.
HighLonesome is offline
post #8 of 18 Old 06-07-2013, 12:30 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I had the exact issue happen to me, and I hate to say it but the pcm could definately be toast.
Originally Posted by HighLonesome
coralman is offline
post #9 of 18 Old 06-07-2013, 01:56 PM Thread Starter
49WillysPU
Had codes read and it showed ignition coil A. Anyone know where it's located
post #10 of 18 Old 06-07-2013, 05:43 PM
coralman
coralman's Avatar
PO350, 351, something like that? Mine did the same. Ignition coil is on passenger side of block, to the right of the distributor.
coralman is offline
post #11 of 18 Old 06-07-2013, 06:22 PM
dellis
2005 WK
That code (I'm guessing P0351) is telling you that a monitor of your Coil Driver is detecting an open or short on the ground line to your coil.
What happened with your Jeep?
dellis is offline
post #12 of 18 Old 06-07-2013, 06:32 PM
coralman
coralman's Avatar
The jeep gave the coil code but there was nothing wrong with the coil, as I had a spare new one, same result. It started random stalling which got worse and worse,ZeeJay ran me through all the troubleshooting but it continued with the coil code. When the O2 shorted{ thanks to a mech who broke the clip} it screwed uo the driver somehow. New pcm and it has ran fine since. Most likely loose solder joints were already present and the short just made them worse.
coralman is offline
post #13 of 18 Old 06-07-2013, 06:46 PM
ZeeJay1997
That code is a weak coil driver circuit in the PCM, bad coil connector, or bad coil.
Given that the o2 sensor shorted out and you havent touched the coil, I'm leaning towards the PCM.
If you're very fortunate, it may only be a coincidence that the connector or coil is bad.
post #14 of 18 Old 06-10-2013, 11:49 AM Thread Starter
49WillysPU
Replaced the ignition coil Saturday and so far so good
post #15 of 18 Old 06-13-2013, 10:44 PM
DickDickle
Originally Posted by ZeeJay1997 View Post
PCM and ASD relay
So would a bad pcm cause that fuse to blow?
DickDickle is offline
