Grand, oil pan removal - JeepForum.com
post #1 of 3 Old 03-14-2002, 09:48 PM Thread Starter
TPolk
I have to put a new rear main seal in my 93 Grand, 4.0, auto w/ Quadra-Trac. Can anyone tell me if & how much I am going to have to raise the motor to remove the oil pan. Any tips or warnings would be greatly appreciated. I had a bad experience removing the pan on my friends Phord Ranger, It threatened our frienship. I swear if Phord made toilets, they would have engineered it so you would have to stick your hand in the water to flush it.
01 Ram W/Cummins
96 & 93 Grand Cherokee
86 Cherokee
NRA Life Member & I vote
TPolk is offline
post #2 of 3 Old 03-17-2002, 07:43 PM
sadler207j
I just pulled the pan off my 93zj, I hydro locked #1 and bent the rod. any way, I had to lossen the starter and disconect the steering stabalizer bar, the pan came right out. I have a 4" lift but I dont see that making and differance. good luck, I know I need it.
sadler207j is offline
post #3 of 3 Old 03-18-2002, 12:46 AM
PEEJ JZ
MY REAR MAIN IS LEAKING ALSO so maybe when your done you could give me some tips. i did use no-leak engine seal and it did help the leak , but for how long? :
if they test drive one they will understand
PEEJ JZ is offline
Distributor Cap Removal from 94 Grand Cherokee V8 ruth ZJ Grand Cherokee Forum 20 09-07-2010 02:54 AM
Grand Cherokee Emblem Removal Oppeau ZJ Grand Cherokee Forum 3 11-14-2005 05:50 PM
Grand Cherokee Badge Removal '95 ZJ SkyjacktZJ ZJ Grand Cherokee Forum 6 11-17-2004 06:46 PM
2000 Grand Radio Removal?? guest WJ Grand Cherokee Forum 1 05-16-2004 02:29 PM
Dash removal on 98 Grand Cherokee twozzie ZJ Grand Cherokee Forum 4 07-23-2003 03:20 PM
