grand not so grand need help quick please - Page 2 - JeepForum.com
post #16 of 23 Old 08-31-2013, 09:35 PM
ilive4cars0122
Originally Posted by wwilly1968
ok sooo today i pulled the throttle bottle completely stripped it cleaned it took a look down her throat and looked pretty clean no puddling of oil carbon but nothing that would suggest plenum not being in good shape,my buddy showed up we did all kinds of stuff and he seems to think that my iac is not fully engaging or disengaging ???
When you mentioned in your first post "falls flat on her face" did you mean it stalls? If that's the case it almost sounds to me like if you replaced the ignition coil it could be a bad part you replaced it with. Just a thought
ilive4cars0122 is offline
post #17 of 23 Old 08-31-2013, 09:37 PM
ilive4cars0122
Oh another thing...I'm too lazy and busy nowadays to re-read other people's posts, but has anyone mentioned the possibility of a clogged catalytic converter?
post #18 of 23 Old 09-06-2013, 06:35 PM Thread Starter
wwilly1968
update so now i have replaced the throttle positioning sensor,fuel pump,fuel filter, crank positioning sensor, plugs, wires, cap, rotor button, coil, temp sensor,and still no good outcome,whats left ummmmmm, computer,and cam positioning sensor, if anybody has any clue please feel free to pm me your thoughts..... I'm done.......
william h davis
wwilly1968 is offline
post #19 of 23 Old 09-06-2013, 10:38 PM
ilive4cars0122
Did you read my last 2 posts? It's possibilities to look at
post #20 of 23 Old 09-07-2013, 08:39 AM Thread Starter
wwilly1968
i did and thanks i literally cut my exhaust before the cat and ran it like that and it still did the same thing, and when i said falls flat on it's face i mean coming to a stop or even taking my foot off the peddle she idles way way way down to just about zero rpm's then just dies....
william h davis
post #21 of 23 Old 09-07-2013, 06:51 PM
dusterdude
Coolant temp sensor?
dusterdude is offline
post #22 of 23 Old 09-07-2013, 07:12 PM
cbr900
1993 XJ Cherokee
I had a broken wire in the harness going up to the injectors that would randomly cut out one of the injectors....took me forever to find. That broken wire really screwed up the idle and it made it miss bad while running. Just a thought
cbr900 is offline
post #23 of 23 Old 09-07-2013, 09:48 PM Thread Starter
wwilly1968
coolant te,p sensor replaced and does function,seems all injectors are working got a new suggestion tonight change the map sensor ????
william h davis
