#1 | |
grand leg room & head room
Guys, I desperately need your input. I've got a 98' Grand Cherokee and I need more head / leg room (I am 6'-3"tall and have size 15 feet) I need to figure out how to move the seat back a bit. Is there anyone out there who's done this?
Re: It looks pretty complicated because of the electric seat stuff ANY advice would be greatly appreciated! THANKS
#2 |
I'm 6' even. I don't have a problem. I wish I could help. I'd imagine you could try to move the mounting brackets back further, but you'd need to disconnect the battery and that because I believe the airbag stuff is under the seat.
#3 |
Perpetually Lost
I'm 6'5", but don't have the clown feet. If you put the seat all the way back, then put the back of the seat bottom all the way down and the front of the seat bottom all the way up, you'll get more leg room. Aside from that method, about the only way you'll get mor leg-room is to unbolt the seat, figure out if bending the front tabs flat and bolting them to the top part of the crossmember that goes through there will work, or move all the way back to the back side of that crossmember and bolt them in there.
edit - and if none of that works, sell the Grand, and get a Mercedes W140 (1992-98' S-class) or 93-01' BMW 7-series, as those are the only two cars/trucks that I have ever been in that if I put the seat all the way back, I can only barely touch the pedals with my tip-toes.
2000 WJ Limited - 2.5" Rusty's springs ¤ WAAG 1-piece front brush guard ¤ custom built WAAG nerf bars ¤ PIAA 580 lighting ¤ Custom Paint ¤ Custom Aluminum Treadplate Door Entry Guards ¤ Custom Aluminum Treadplate Rear Bumper Step 1986.5 Porsche 928S - 18" Moda MD1 ¤ Autothority Chips ¤ Rear Muffler Bypass ¤ Short-Shift Kit |
#4 |
I'll chime in here too. I'm 6' 4", and I didn't have a problem fitting in a Laredo. My head brushes in my Limited (because of the sunroof), but it isn't bad. My size 10.5 feet fit under the dash ok too. So based on this, I am thinking you don't really need more leg room, but rather more foot room .
Buddha's bit about tilting the seat back is right on, you gain a surprising amount of room when you do that. Of course nobody can sit behind you.... Here's some other stuff to try: Remove the rubber covers from the pedals and remove the knee board trim across the bottom of the dash. If these two things make life better for you, then I suggest covering the exposed support on the dash with wood trim contact paper, or maybe painting it with wrinkle finish black paint, then replace the pedals with some of those aftermarket "carbon fiber" ricer pedals. You can also remove the cover from your seat. You'll notice there is a lot of cotton batting under there. You could probably remove some or all of that and replace it with contoured high density foam. Less bulk, but just as much support. HTH
Warren Black 1996 5.2L ZJ Limited |
#5 |
I think Buddha's Idea of moving the bolt tabs to the back of the rail will work ..You will have to drill holes and get yourself some 2 1/2" bolts to go all the way thru.
And if you still need more room .. You could just use some pipe nipples to make spacers for the front and move the seat as far back as you want... ![]()
Just another soccer moms Grocery getter.... [Url]http://www.jeepforum.com/gallery/files//8/5/6/5/hatt034.jpg[/url] |
#6 | |
#7 | |
#8 |
haha Get back to giving advice before I get you in trouble. Wanna switch feet?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
