Grand Jeep Cherokee wont turn over, just clicks - JeepForum.com
post #1 of 4 Old 07-08-2013, 04:55 PM Thread Starter
ntbctatum
Ok. So the battery, battery cables, AND the starter have been replaced, but no luck. Please help!
ntbctatum is offline
post #2 of 4 Old 07-08-2013, 06:34 PM
gearheadnick
First thing to take apart and clean are the grounds. Verify the battery terminals are making good contact, wire brush or file the contacts just to make certain. Verify that all the wires are hooked up properly to the starter.
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
post #3 of 4 Old 07-08-2013, 07:57 PM
dellis
2005 WK
Let me give you some simple things to do, and if they don't work, then do what gearheadnick wrote.
Assuming all your components are good (battery, connections, and starter), here's a quick 1-2-3:
(1) Just to be clear, was the starter solenoid replaced as well (it is usually replaced with the starter, but I am double checking). If not, then I would suspect that to be your problem.
(2) Will it start when you place the shifter into NEUTRAL? If so, then your neutral safety switch is defective.
(3) The horn relay and the Engine Starter Motor Relay in the Power Distribution Center are likely the same. Switch them and see if it will start. If it does, your relay is bad.
dellis is offline
post #4 of 4 Old 07-08-2013, 08:46 PM
papitt
... I too was going to say .. Check every ground you can find .. NOW Try and start it at each point. Because when you find it ..This little Gremlin may pop up from time to time. You want to be able to go pinch his head off in just a few minutes next time.
papitt is offline
