Grand Cherokee won't stay running - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Grand Cherokee won't stay running
Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri2007-2016 Jeep JKU 4" X-series suspension lift **dea
Unread 11-27-2011, 11:41 PM   #1
JackJack
2008 WK
After Irene hit, I had to drive my 95 grand Cherokee through water that was up to the fog lights and grill area. After that it ran perfectly for about a week and then I was driving on the highway and the jeep starting "bucking" I managed to get off at the next exit before it completely died, after that it wouldn't start and then about a week later I tried again to start it and it ran for at most 10 seconds. I've checked all of the spark plugs and they Are fine I can't think of anything else to check. any suggestions? Please help me get her back on the road, 3 months is way to long with out a jeep!
08 Grand Cherokee Limited Hemi
05 Grand Cherokee Limited Hemi
Sold - 04 TJ, 95 ZJ, 01 WJ
JackJack is offline   Reply With Quote Quick reply to this message
Unread 11-28-2011, 12:38 AM   #2
caligiuri87
1994 ZJ
check the coil in front and check your alternator as well. check the grounds and batterie connectors. other than that u could check the computer by the firewall behind the coolant bottle. when it ran did it smoke? check oil and coolant. if it is milky then u sucked wate in the airintake and could blown ur headgasket.
Shaky.......shaky shaky shakyyyyyyy.....crack boom pow @%^@%@%@$@#$^%&*(^&&%$@!!!!!!
Happy to be a JEEP owner
caligiuri87 is offline   Reply With Quote Quick reply to this message
Unread 11-28-2011, 12:43 AM   #3
phitmein
phitmein's Avatar
spray WD-40 inside the dist. and its cap and retry.
I would also disconnect the battery for an hour or two to reset the puter.
phitmein is offline   Reply With Quote Quick reply to this message
Unread 11-28-2011, 07:13 AM   #4
JackJack
2008 WK
The water level was below the air intake, and no smoke
Unread 11-28-2011, 11:17 AM   #5
cody_love
1989 XJ Cherokee
sound like it could be the distributor i dont this playing in the river you can either let it sit and dry itself out or some people use a hair dryer i would try that
cody_love is offline   Reply With Quote Quick reply to this message
