Grand cherokee and wagoneer - JeepForum.com
post #1 of 5 Old 04-30-2013, 05:31 PM Thread Starter
gdeckerjr
I can get an 88 jeep grand wagoneer 4.5 in lift cheap with bad motor I have a 96 jeep grand cherokee with a bad trans is the trans the same from what I can see it is and how about suspension? Any info would be appreciated thanks guys in advance
gdeckerjr is offline
post #2 of 5 Old 04-30-2013, 05:38 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Pretty sure its coils vs leaf springs, so no suspension. And I think the trans was a 727 or 518 on '88, so no go there too.
Get a second opinion
HighLonesome is offline
post #3 of 5 Old 04-30-2013, 09:06 PM
kensnelling
X2, totally different suspension, an SJ had leaf springs on all four corners where your ZJ has coil springs on all four corners.
The transmission in the SJ is a 3 speed hydralic controlled transmission where your ZJ has an electronic controlled 4 speed overdrive transmission. Plus, the bellhousing bolt pattern is different on the 360 AMC engine.
kensnelling is offline
post #4 of 5 Old 04-30-2013, 09:17 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
pretty much nothing the same between them. a few bolts.
ratmonkey is offline
post #5 of 5 Old 04-30-2013, 09:30 PM
dnuccio
other than theyre both jeeps and they are both "grand"
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
