Grand cherokee transfer case swap - JeepForum.com
post #1 of 2 Old 01-07-2002, 08:36 PM Thread Starter
Trader869
i have a '94 grand cherokee limited V-8,has the 249 NP fulltime case,its going bad,so i need to find out what year 231NP or 242NP will fit,if they even will?I know the grands had 231NP,242NP and 249 NP with 249 the only option with the V-8.tried to replaced a friends 6 cyl. with a 249 with a 249 out of a V-8 and the input shaft for the transfer case was longer on the V-8 case....couldnt find another good one so we cut the shaft to fit on that one,so my question is ...will the 6 cyl. 231 or 242 fit,or will the input shafts be too short,hope someone did this swap and can give me some advice......thanks!!!
Trader869 is offline
post #2 of 2 Old 01-08-2002, 08:23 AM
Mackskibum
1976 CJ7
I did the 231 swap. As far as I know the 242 and 249 input shafts are the same, so you could just change the input shaft from your 249 into the 242. I used a 231 from a TJ w/ 4.0, it bolted in and had the correct input shaft. I did have to change the front output yoke to one from an XJ so it would accomodate the double cardan u-joint. Also, the 231 won't work with the VIC, and you have some field engineering to do to make the linkage work.
HTH
'05 GMC Envoy XL SLT
'05 F250 CC XLT 4x4
'08 535XI
'76 CJ7 project
Mackskibum is offline
Grand cherokee transfer case swap JgrandC ZJ Grand Cherokee Forum 5 04-11-2012 09:44 AM
Grand Cherokee Transfer case only works in 4WD littlefdl ZJ Grand Cherokee Forum 12 03-21-2009 05:26 PM
Will A 242 Transfer Case From A 90 Cherokee Fit In My 99 Jeep Grand Cherokee.?? squirrly ZJ Grand Cherokee Forum 8 03-05-2009 05:55 PM
Replacing transfer case in 99 Grand Cherokee jamjr74 ZJ Grand Cherokee Forum 2 01-27-2009 10:51 AM
transfer case- 94 grand cherokee capone518 ZJ Grand Cherokee Forum 4 05-18-2008 11:00 PM
