Grand Cherokee Shake Shack - Vibration - JeepForum.com
post #1 of 4 Old 08-27-2003, 08:56 AM Thread Starter
PorschePusher
We just overhauled the viscous coupling in our 94 GCL with mixed results. After noticing that one of the tires that NTB installed was a different rating (but right size) and had worn faster than the others, it became obvious why the 4 wheel drive system was starting to fail. So we put in new front drive axles and had the transfer case rebuilt.
Here's the issue: At 50 MPH and above, the whole truck vibrates like crazy. We thought replacing the VC in the transfer case would solve the original issue of bucking and jumping and also the vibration problem. It didn't solve the virbration problem and its been getting notacably worse.
NTB replaced the front tires, rebalanced all 4 and did the alignment. So that rules out the vibration being a tire issue. The virbration is most noticable under accelleration so we're pretty sure its drive train related.
Anyone been down this road before??
PorschePusher is offline
post #2 of 4 Old 08-27-2003, 09:00 AM
Swamp Boy
Swamp Boy's Avatar
Check you drive shaft to see of you need new U-joints and make sure the balance weight is still on it..
Also might try replacing steering stabilizer..
Hope that helps..
Carl
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #3 of 4 Old 08-27-2003, 09:04 AM Thread Starter
PorschePusher
Are these the U-joints on the drive shafts that come out of the transfer case (forward and backward)?, I'm not familiar with the counter weight. Whats it look like?
Thanks for your response!
post #4 of 4 Old 08-27-2003, 08:03 PM
JEEPTECHNICIAN
A common problem with vibration in a grand a higher speeds is the front drive shaft. The only way to verify this is to pull the front drive shaft and drive it again. "BEWARE WHEN YOU PULL A FRONT DRIVE SHAFT FROM A ALL WHEEL DRIVE 93-98 GRAND CHEROKEE IT WILL NOT HOLD IN PARK, IT WILL ROLL IN PARK." KEEP THIS IN MIND PLEASE......
JEEPTECHNICIAN is offline
98 Grand cherokee 4.0 front vibration n00blike ZJ Grand Cherokee Forum 6 03-08-2011 08:53 PM
Grand Cherokee Vibration Bonger ZJ Grand Cherokee Forum 3 01-17-2008 11:54 AM
1996 Grand cherokee tranny shake???? montemann ZJ Grand Cherokee Forum 4 04-16-2005 01:07 PM
04 - I6 Grand Cherokee CE - Vibration/Miss MeanFLKitty ZJ Grand Cherokee Forum 2 03-22-2005 07:15 AM
94 grand cherokee vibration mwag5535 ZJ Grand Cherokee Forum 2 12-21-2004 10:57 AM
