Grand Cherokee's best year - JeepForum.com
post #1 of 19 Old 01-04-2005, 04:46 PM Thread Starter
cbadal
Hello all,
I am new to this forum (and to Jeeps). I have a 2000 Jeep Grand Cherokee (6-cyl) and I my radiator fan relay went out.
I got the part at an after market part store and then proceeded to attempt to change it.
To my surprise it was nowhere to be found.
I called up a local dealer and asked the parts department if this part was on my model.
They said that it was, and that it is burried. They told me that in order to replace this part, one must first take off the bumper and a couple other things to get to it.
Now I'm pretty pissed at Jeep for putting a part with a high failure rate in such a difficult location.
My question is "Is there any year for the Grand Cherokee which is easy to work on?"
cbadal is offline
post #2 of 19 Old 01-04-2005, 05:39 PM
madmax
madmax's Avatar
Originally Posted by cbadal
Hello all,
High failure rate? I DON'T think so!!! I have a '00 Grand Cherokee and didn't have any major problems with it yet....
-madmax
2000 WJ 4.0L, drop-in K&N filter, Addco rear antisway bar, Bridgestone Revos, Overhead DVD monitor w/ wireless headsets.
2007 BMW 335i, Montego Blue with Lemon seats, premium & sport package.
2004 TJ Sport 4.0L - SOLD :(
madmax is offline
post #3 of 19 Old 01-04-2005, 05:57 PM
my95yj
this thread makes me laugh, is there any year of jeep made that is easy to work on?
95 YJ
my95yj is offline
post #4 of 19 Old 01-04-2005, 06:01 PM
Meerkat
Well, I used to own a 1985 Camaro, and I can attest, my ZJ is much easier to work on than it was...
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #5 of 19 Old 01-04-2005, 07:28 PM
ZgreatJ
Rain Man
ZgreatJ's Avatar
Hey Warren, I currently have an 87 GTA, not too bad to work on. But that is because I removed the AC and all of the smog equipment also, and I mean all. Even the headers have no AIR tubes on them. Now my 95 Formula, that is a different story, I haven't even begun to play with that one yet because it is so crammed under the hood. But back on the topic. The few things I've done so far on my ZJ have been fairly easy. I have never done an easier full tune up. And the alt, radiator and WP were just time consuming, not really that difficult. I just did shocks last weekend and the only hold up was having to get the right right wrench(yes it was 18mm)for the rear bolts. I have had the dash apart a few times already, nothing really difficult there. So overall, I'd have to say working on a ZJ isn't too bad.
RIG#1 96 Forest Green ZJ Laredo-4.0 I6 242
GREEN JEEP CLUB MEMBER #136
Kevin's 4.5 lift-Kevin's Rock Sliderz-Custom 4X4 Fab Front Winch Bumper-T Max EWI 10000 winch-32X10.50-15 Super Swamper TSL Radials on US Wheel 15X8 Black Steelies-OME SS-Rusty's steering conversion-SOLD
Currently- 98 ZJ Limited-99 XJ Classic-Both stock for now
ZgreatJ is offline
post #6 of 19 Old 01-04-2005, 07:34 PM
jeepholic
jeepholic's Avatar
CPS worst location ever
Heater core worst location ever
Rear door speakers, worst location ever. ( I keep my seat down in the back and they fire into the seats, sounds great.)
Distributor on a V8, worst location ever.
ON TOP OF A TRAIL THAT NO ONE CAN GET TO BUT YOU
Best location in the world.
I keep da chity ZJ.
OH YEA! Now I have a 4" lift, you can almost walk around underneath.
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
Black Jeep Club Member Ver. 2 #51
jeepholic is offline
post #7 of 19 Old 01-05-2005, 09:00 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
94 Baby,
the best year for them.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #8 of 19 Old 01-05-2005, 11:15 AM
my95yj
how did i know you would put 94.....some people.....
95 YJ
my95yj is offline
post #9 of 19 Old 01-05-2005, 11:29 AM
Meerkat
I'm still trying to figure out how that fan relay qualifies as a high-failure item. If I'm reading cbadal's post right, it appears this is the first time that part has failed on his Jeep...
Warren
Meerkat is offline
post #10 of 19 Old 01-05-2005, 11:39 AM
Chrisca
Chrisca's Avatar
How do you know it went out if you don't even know where it is located to have tested it?
2004 Grand Cherokee Laredo
Chrisca is offline
post #11 of 19 Old 01-05-2005, 12:25 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
94 Baby
The only way to go.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #12 of 19 Old 01-05-2005, 01:30 PM
greasefingers
greasefingers's Avatar
1994 ZJ
94 is indeed the best and it helps to have a black one
The relay is hidden somewhere in the bumper. But you can trouble-shoot some of this circuit. The connector from the relay to the fan is located behind the passenger headlight. So you can measure 12v on the Dark green wire here, only after the temperature of the coolant is hot. Also check for ground at this location on the black wire with pink stripe. If the relay is not being supplied with power, then you are screwed because now you have to find this relay and trouble-shoot at its location.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #13 of 19 Old 01-05-2005, 01:39 PM
my95yj
in 94 i heard jeep made special lugnuts that fell off while traveling at high speeds!
95 YJ
my95yj is offline
post #14 of 19 Old 01-05-2005, 01:48 PM
jeepholic
jeepholic's Avatar
Yes that's true but they will fit on your Jeep as well.
I use a Jeep
You drive a car
Big difference.
post #15 of 19 Old 01-05-2005, 07:34 PM
deeger
deeger's Avatar
Best Jeep is '94
I've had good luck with my '94 Laredo...160K miles later...I'd rather buy used than new. 5.2L is the best powerplant under the hood. Aside from the dreaded viscous coupler failure, and lack of AC, its been reliable.
Deeger
If it ain't broke...fiddle with it 'til it is
'94 ZJ Black 5.2 V8, AMRacing Wheels, BFGs, 160K miles
'95 BMW 525i stock
'97 Honda CBR900RR Erion Racing Edition
deeger is offline
Any high mileage Grand Cherokee's Passatglx WK Grand Cherokee & XK Commander Forum 184 02-27-2014 09:31 PM
1994 Grand Cherokee's back door won't open irishman1952 ZJ Grand Cherokee Forum 8 06-10-2012 07:18 AM
Grand Cherokee's Down Under (Australian grand forum) theksmith ZJ Grand Cherokee Forum 6 08-30-2008 01:01 PM
2008 Grand Cherokee's WKJeepGuy24 WK Grand Cherokee & XK Commander Forum 11 05-12-2007 08:52 AM
Custom rims for jeep grand cherokee's dkostis ZJ Grand Cherokee Forum 2 12-14-2003 09:22 AM
