Grand Cherokee power lock issues - JeepForum.com
post #1 of 10 Old 06-11-2009, 09:02 AM Thread Starter
Char250r
When the old lady hits the power door lock button, 2 doors lock, the other 2 just buzz and remain unlocked. I would imagine that 2 of the door lock motors (or whatever is in there) are broken. Anyone ever had to change these before? Just looking for some info before I start removing the door panels. Thanks.
Char250r is offline
post #2 of 10 Old 06-11-2009, 09:07 AM
DothanJeep
What year Grand Cherokee?
00' WJ 4'' IRO 285 Tire...Ect-SOLD 7/2/2009
98' ZJ STORM TROOPIN' SOLD
97' ZJ with 117K THE DD mi SOLD
01'WJ Project Cheap fix.
DothanJeep is offline
post #3 of 10 Old 06-11-2009, 12:48 PM Thread Starter
Char250r
The Cherokee is a 2000
Char250r is offline
post #4 of 10 Old 06-11-2009, 01:39 PM
Double E
Double E's Avatar
It's a piece of cake. I did two myself in about an hour and I took my time. All plug n play stuff. It would take a 9th grader about the same amount of time.
Remove the philips screws from the mid section of the door first. You'll break some door panel clips prying off the panels but it will still go back together ok. The dealer or a parts store probably has em. I think you may also need a torx bit to remove the "door lock actuator" (which is the part you need for this).
Be careful in disconnecting the wiring harness from the door panel.
The only tough part is accessing the rods the actuate the door handle and getting the "keepers" off of each rod without cutting into your hand or breaking anything.
PM Kolak for a good price. Tell 'em what you need, he'll send it you you and it will be blatently obvious what you need to replace after that.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #5 of 10 Old 06-11-2009, 02:18 PM
gmp211
Your gunna need to check the lock actuator. The buzz is that lock trying to engage but can't. Sometimes you can spray some WD-40 on them an they'll work. But most of the time you'll need to replace them.
My rear hatch had the same problem and I needed to manually lock and unlock it. Just bought a new actuator, and waiting to install it.
2002 WJ - Forest Green
gmp211 is offline
post #6 of 10 Old 06-12-2009, 01:37 PM
Double E
Double E's Avatar
Almost forgot.... read this over too.
http://www.jeepslimited.com/index.ph...d=17&Itemid=93
Double E is offline
post #7 of 10 Old 06-13-2009, 04:32 AM Thread Starter
Char250r
Double E: excellent thread with pics. I wish I saw the post before I took the door apart. Taking the door apart was a piece of cake. I took out the actualor, cleaned and lubed it, and it still buzzes and doesn't move. Time to get the wallet out and buy a couple new ones. Where can I get them besides my local stealership? Who and where is this Kolak you mentioned?
Char250r is offline
post #8 of 10 Old 06-13-2009, 08:48 AM
ZooTech
All four of mine went bad and I simply unplugged them, leaving them in place, and installed aftermarket actuators (like $5.00 each from places like Parts Express). I then installed an aftermarket keyless entry unit which powers them but you could just as easily use the factory actuator wiring to run them.
http://www.parts-express.com/pe/show...number=330-010
http://www.millionbuy.com/accdoorlock.html
~ 1995 ZJ
~ np242
~ 2.25" BB
~ Rough Country Nitro 9000 shocks
~ 31x10.5x15 Dunlop Radial Mud Rovers
~ 15x8 black Unique wheels
ZooTech is offline
post #9 of 10 Old 06-15-2009, 08:59 AM
Double E
Double E's Avatar
kolak@aol.com or you can PM him through the forum. He posts in many threads on exhaust, sway bars and other such upgrades as well.
ZooTech has a good point but I don't know if that setup will work on the WJ.
Double E is offline
post #10 of 10 Old 03-19-2011, 03:48 PM
mthunderwolf
1998 WJ
Grand Cherokee Door Lock Actuator
I did a search and found this thread and am having a problem with my driver side rear door lock. Can any of you guys tell me where I can get the replacement actuator without going to a dealer but get a good quality part?
Thanks!
mthunderwolf is offline
Grand Cherokee power window/lock problem 737FlyGuy ZJ Grand Cherokee Forum 69 01-04-2017 04:54 PM
1996 Grand Cherokee power window and lock problem jrenegade13 ZJ Grand Cherokee Forum 2 12-31-2011 09:36 AM
wondows and power lock issues. gonejeepin04220 ZJ Grand Cherokee Forum 3 09-14-2009 10:52 AM
94 grand cherokee laredo power lock problem 2wdGrand ZJ Grand Cherokee Forum 3 07-11-2007 09:16 PM
Power lock info needed 2000 Grand Cherokee the_nite_owl ZJ Grand Cherokee Forum 0 07-21-2005 12:31 PM
