Grand Cherokee 1998 5.9 - JeepForum.com
post #1 of 7 Old 04-19-2012, 11:16 AM Thread Starter
bubba7gump
My 5.9 has been in the family since new and I am the second owner. I have installed new front and rear axles, ball joints, shocks, brake rotors, calipers, pads, after market front and rear sway bars...power steering pump,on and on. However there is one small item that I have yet to be able to solve, maybe there are some clues you guys can provide??
I have replaced the "Coolant Temp Sensor" due to the warning that is displayed on my info display. The problem I a having is that I have had to replace it THREE times and keep getting the warning that it is bad.
I have the Factory Service manual for 1998 that covers the 5.9 engine, so I have researched but I am still at a loss as to what I should do next...ANY HELP is APPRECIATED!
bubba7gump is offline
post #2 of 7 Old 04-19-2012, 11:21 AM
Timo_90xj
Timo_90xj's Avatar
VIC can throw random warnings even though there's nothing wrong with the things it monitors... I get a rear light failure warning every time I fire up the Jeep and hit the brakes the first time - all my rear lights work perfectly fine. Coolant temp sensor warning I believe is one of the most common ones you will see.
Just ignore it, if you get annoyed by the beeps VIC makes, unplug it and be happy with it. I'm sure there is a way to fix it the right way, but I have no idea if it's easy or cheap - or not. I can live with the beed it makes the first time I hit the brakes, but if my VIC starts giving more false alarms, I'll probably just unplug it.
***Under construction***
Timo_90xj is offline
post #3 of 7 Old 04-19-2012, 11:26 AM
ElkhornRanch
Might be a loose solder on the VIC board. You can pull it and look it over, touching up solder points.
ElkhornRanch is offline
post #4 of 7 Old 04-19-2012, 11:29 AM
Technohead
Coolant sensor bad is a well know problem. I have yet to see a GC of that vintage that did not have the "bad coolant sensor". Somebody already mentions the problem is causes by failed solder connection in the VIC. There are many write-up on the fix.
I've just been living with the annoying beeping for the past 14 years.
-Eric
Technohead is offline
post #5 of 7 Old 04-19-2012, 12:27 PM
PolkaPower
Mine isn't broken yet but I'm pulling the vic out anyways to replace it with some switches and gauges. It's the vic, your truck is fine.
PolkaPower is online now
post #6 of 7 Old 04-19-2012, 12:31 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
As mentioned, many threads regarding this. Here's one:
http://www.jeepforum.com/forum/f13/c...7/#post1274979
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #7 of 7 Old 04-21-2012, 11:40 AM
MaintMech
Old and in the way
MaintMech's Avatar
And it's companion.
http://www.jeepforum.com/forum/f13/c...moval-1228233/
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
1998 Grand Cherokee FWD, RWD or AWD? bigislandhikers ZJ Grand Cherokee Forum 6 02-13-2012 08:35 AM
1998 grand Cherokee 5.9 vs 1999 Cherokee 4.7 rrich49132 ZJ Grand Cherokee Forum 89 11-27-2010 06:11 PM
1998 Grand Cherokee T/C questions Warmbolds ZJ Grand Cherokee Forum 6 10-26-2009 08:20 PM
Help for a 1998 Grand Cherokee TSI lori2stj ZJ Grand Cherokee Forum 11 01-04-2009 11:06 PM
1998 Grand Cherokee LTD suspension? ItsJustMe ZJ Grand Cherokee Forum 1 06-03-2003 06:39 PM
