Govenor pressure solenoid / pressure sensor / overdrive and lock-up solenoid - JeepForum.com
post #1 of 5 Old 02-27-2016, 12:19 PM Thread Starter
technophat
I am writing this to show how to replace the Govenor Pressure Solenoid, Transmission Pressure Sensor, and the Overdrive and Lock-up Solenoid.
In this link https://www.youtube.com/watch?v=Wtgdu01ECtI he shows how to remove the valve body, but you can replace the Govenor Pressure Solenoid and the Transmission Pressure Sensor parts by just dropping the transmission oil pan and removing the filter with a standard socket set and a Torx - T25 screwdriver. Replacing the Overdrive and Lock-up Solenoid will require you to remove the valve body, and if you're already into the oil pan, it's not difficult to remove the valve body and replace all three parts.
Pic #1 shows the back side of the valve body. The black circle on the upper left hand corner is the electrical connector that pushes through the transmission case. On the other end of this connector is the Overdrive and Lock-up Solenoid, shown connected the the wire in the pic.
Pic #7 shows the three parts installed on the valve body and the three old parts just beside them.
Pic #8 shows the Transmission Pressure Sensor and the "M" or "W" shaped clip that holds it into place.
1997 ZJ Laredo, 4.0, 42re trans, 242 T-case
1994 ZJ Laredo, 4.0, 42re trans, NP231 T-case
technophat is offline
post #2 of 5 Old 02-27-2016, 04:55 PM
ZeeJay1997
Thanks for taking the time to share this method of getting the electronics changed out.
If you want to change the OD solenoid without taking the valve body off, see this write-up
ZeeJay1997 is offline
post #3 of 5 Old 02-28-2016, 06:58 AM
gearheadnick
LOL ZeeJay, you beat me to posting my link.
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
post #4 of 5 Old 02-28-2016, 07:42 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I put it out there on some post the other day too, a real time saver nick!
Originally Posted by HighLonesome
coralman is offline
post #5 of 5 Old 02-28-2016, 08:37 AM
ZeeJay1997
Especially if you're laying on your back with fluid running down your forehead.
