Got a pop? - JeepForum.com
post #1 of 2 Old 02-26-2002, 04:03 AM Thread Starter
turk
Got a pop?
Ok all,
Here goes, installed a 3" teraflex lift. Only got the adjustable control arms for the upper and lower rear, nothing for the front. Relocated the front track bar on existing bracket, lowered the tranny 3/4 of an inch. Checked all connections to make sure they are secure and snug. On initial excellerations and upon braking, I get a farirly loud pop from under the drivers seat! Well, at least it is somewhere in that area. My first guess is... perhaps the u joint in front is binding and popping at the transfer case. It is not a constant occurance. There are times where I can't make it pop. I cannot see any visible indication of binding or of anything coming in contact with another part of the under carriage. Any thoughts?
Thanks in advance!
Turk
It doesn't matter what you drive as long as it is a JEEP.
98 JGC Laredo 4.0, 3" lift, Rustys adjustable UCA's & LCA's, Custom K&N intake, high flow exhaust, Jet chip Stage 2 and 32x11.5 BFG TA's
turk is offline
post #2 of 2 Old 02-28-2002, 05:32 PM
mattvw65
how did you install your shocks the factory bilsteen shocks are mounted up side down i bought pro comp shocks and installed them up side down they made a popping sound i simply took the shocks off and cycled them all the way up and down and installed them the right way this fixed my problem hope this helps
Matt
96 jeep grand Cherokee 3.25 teraflex
73 vw thing
Put your seat belt on I want to try something !!
mattvw65 is offline
