Got a new starter... - JeepForum.com
post #1 of 4 Old 03-07-2013, 08:14 AM Thread Starter
KJK
And it killed my harmonic dampener.
First, the starter story:
From Rockauto.com for $75. Brand new and no core charge. Jeep was cranking a little slow sometimes and then the other day I came out from driving to the store to be met with just a "CLICK" when I turned the key. After about 8 more tries it fired up and had been O.K. (it was starting) for the past few days but I knew it's days were numbered.
When I hit the key on this new starter it cranked as if I had 2 batteries! Those old contacts were definitely causing alot of resistance.
3 days later:
The jeep all of a sudden develops a bad vibration at 1500 rpm. A quick search revealed this is a common sign of a failed dampener especially on a high mileage engine (149k). I had no check engine light so therefore no engine miss and all the mounts are pretty new.
I believe the hard hitting new starter provided the final death blow to a failing dampener.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #2 of 4 Old 03-07-2013, 08:42 AM
caseyliffick
I'm about to buy a new starter myself. It takes a second for mine to start, and the other day I has to get underneath the jeep and bang on the starter with a wrench for a sec. Hasn't given me trouble since, but I'd rather be safe than sorry.
caseyliffick is offline
post #3 of 4 Old 03-07-2013, 10:19 AM
bananaslug
I got mine from Oreillys. It was something like 60$ plus a core, and a lifetime warranty.
Before getting one, clean the connections (probably covered in oil) and test the battery.
bananaslug is offline
post #4 of 4 Old 03-07-2013, 10:35 AM
xcaliber81
I had replaced mine because my oil leak was getting in my solenoid and when I got cold out it would do nothing no click nothing until I jumped the starter and it start overtime until it sat in the cold again.
xcaliber81 is offline
