Got my Lights put on :) - Page 2 - JeepForum.com
post #16 of 36 Old 05-10-2011, 05:41 PM Thread Starter
niles6284
Originally Posted by 1stblack97ZJ View Post
how do you like where your CB is?
Hey thanks for asking, I like it pretty well, its out of the way, and makes it easier to hear for me being right near my head. no issues with it falling or the mic cable getting in my way.
98 ZJ 4.0 Lifted with stuff
2001 WJ not lifted no stuff
Firefighter/Paramedic
IAFF Local 379
niles6284 is offline
post #17 of 36 Old 05-10-2011, 05:44 PM
1stblack97ZJ
Hmm, I like were you put it more than were most put it. I think when I get mine I'll put it where you put yours.
What antenna do you have?
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #18 of 36 Old 05-10-2011, 05:44 PM
Freestyle713
1994 ZJ
http://shop.advanceautoparts.com/web...___#fragment-3
these ones are nice too. just bought 2 and put them on my bull bar. bright as ****. wanna buy 4 more to do the same thing you just did. looks great
Freestyle713 is offline
post #19 of 36 Old 05-10-2011, 05:48 PM Thread Starter
niles6284
thanks man, glad you like it. I have the uniden pro 510XL. The antenna is a Wilson Lil Wip. I get great reception with it and everyone that I have talked to out on the highway can hear me clear for atlest 5 miles out. this being figured by intensive math usage lol
IAFF Local 379
post #20 of 36 Old 05-10-2011, 05:50 PM Thread Starter
niles6284
thanks man, those are good lights for the money too, I have had my share over the years on different vehicles of mine. good luck with your install.
IAFF Local 379
post #21 of 36 Old 05-10-2011, 05:50 PM
1stblack97ZJ
cool! I'm looking at either Cobra or Uniden for a CB..
and antenna wise, i was thinking a 102" steel whip, lol
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #22 of 36 Old 05-10-2011, 05:56 PM Thread Starter
niles6284
You can get a Uniden like mine for like 30 dollars off craigslist around me, I think they are 40 used from uniden.
I will be going to a whip when I get my rear bumper built up it will be going back there. the uniden I have is great for the money, it does what it needs to do for sure
IAFF Local 379
post #23 of 36 Old 05-10-2011, 07:06 PM
95_ZJ_Limited
Did my KC's roughly the same way. Ran all wiring through the trox screw hole and made switches in the headliner. Connected wires to different fuses on the passenger side
1995 ZJ Limited. Lifted, AW4 & 4X4 swapped
Build Thread: Jeep Grand Hilton
Built Not Bought # 529
95_ZJ_Limited is offline
post #24 of 36 Old 05-10-2011, 07:48 PM Thread Starter
niles6284
lookin good man
IAFF Local 379
post #25 of 36 Old 05-10-2011, 07:58 PM
Freestyle713
1994 ZJ
did you remove your headliner? cause it looks like you did. if you did, then im probably gonna rip mine down too since its sagging a lot, doesnt look bad the way you have it
post #26 of 36 Old 05-10-2011, 08:26 PM Thread Starter
niles6284
yes I did, removed all of the grab handles, sun visors, and clips took it all out, tore off the fabric, cleand off all the foam on the underside and took truck bed coating to it. like it pretty well.. need to do a few more coats I think though.
thanks for noticeing
IAFF Local 379
post #27 of 36 Old 05-10-2011, 10:57 PM
Pugulis
I have the exact same ones. They are supper bright. 4 more on top would be sick.
Hey all here are a few photos of my light install, I put on 4 Hella 500FF's. Not sure if anyone has done this install like this but might as well put it up, who knows it may serve as inspiration to someone to do it.
I installed all the relays that came with the lights in the upper console along with the switches, made it to where I could either have the outer two on or the inner two on seperate from one another, or just have all of them on.
ran the wires between the headliner and the roof, down behind the passenger side pillar fascia and into the engine bay. then from there they went up through the metal clip on the side of the windshield up to the stock roof rack mounts. my "light bar on a budget'' but never the less it works great. all wires are covered in wire loom and will soon be soldered at every connection to assure connectivity. let me know what you all think. thanks for looking; any other questions feel free to ask.
Your lights look a little dim. Did you run the power directly from the battery for EACH set of lights? If not, your losing some power when you run all 4.
[_][]☺[][][]☺[][_] 96' Grand Cherokee Laredo 265,000 miles and still going strong.
Pugulis is offline
post #28 of 36 Old 05-11-2011, 04:20 AM Thread Starter
niles6284
Your lights look a little dim. Did you run the power directly from the battery for EACH set of lights? If not, your losing some power when you run all 4.[/QUOTE]
it was just the flash on my camera interfering with them, they are really bright.
IAFF Local 379
post #29 of 36 Old 05-11-2011, 04:11 PM
95_ZJ_Limited
lookin good man
Thank you
post #30 of 36 Old 05-17-2011, 05:15 PM
Freestyle713
1994 ZJ
got my lights put on, too. not hooked up yet, tho.
no parking lights, rear wiper, dash lights flash with blinker kemicalburns ZJ Grand Cherokee Forum 6 04-23-2010 08:45 PM
Installed roof lights and made a switch panel for my lights aaron7 ZJ Grand Cherokee Forum 11 04-15-2009 11:32 AM
Ceiling lights/visor lights dont work (good light bulbs) Wade3114 ZJ Grand Cherokee Forum 5 03-09-2009 04:34 PM
No dash lights or tail lights - instantly blowing fuses oxrageous ZJ Grand Cherokee Forum 2 11-01-2007 08:00 AM
1998 JGC limited 5.9 dome lights and heater control lights problem zoom248 ZJ Grand Cherokee Forum 6 04-12-2004 05:02 PM
