Got my lift on and now looking to improve ride - Page 2 - JeepForum.com
post #16 of 29 Old 04-06-2009, 07:36 AM Thread Starter
kmk108
After spending a lot of time looking at different things, I think i'm going to end up getting a pair of RE springs and a set of Bilstein 5100. From what I've heard about them and for $59.99 a shock with their buy 3 get 4th free deal, it seems too good to pass up.
My new ? is, If they will solve my ride problem, which one should I get first. Cash won't allow me to get both now. Which one will help the most now? Shocks or Springs?
30 BFG A/T, Flowmaster Super40, Alpine head unit, Alpine amp, Rockford speakers, Sony subs, cobra cb
White Jeep Club Member #108
2009 FA CUP CHAMPIONS
CAREFREE, WHEREVER WE MAY BE
WE ARE THE FAMOUS CFC
AND WE DON'T GIVE A F@#K
WHOEVER YOU MAY BE
CUZ WE ARE THE FAMOUS CFC
kmk108 is offline
post #17 of 29 Old 04-06-2009, 08:03 AM
rugermack
I think Kolak has the MX6 shocks on sale, you could then adjust the ride to where ever you like it. It would suck to buy more shocks to still have a stiff ride. Try the adjustables.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #18 of 29 Old 04-06-2009, 08:53 AM Thread Starter
kmk108
does kolak have a website? I've tried google searches before and couldn't find one
WHOEVER YOU MAY BE
kmk108 is offline
post #19 of 29 Old 04-06-2009, 09:01 AM
GraKee99
Rapist Wit
GraKee99's Avatar
It is under construction, email him at Kolak@aol.com and tell him you are from JF.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #20 of 29 Old 04-06-2009, 09:37 AM
Eldoradoman
They don't make an MX-6 shock for 3.5" lift, stick with the Bilsteins or ask Kolak about the RE Monotubes.
1998 Bright Platinum 5.9, 242 swap, go-fast goodies ,and 3" exhaust w/Super 40, SCT Tuner, 4" hybrid lift, 33" Claw TTC Radials
Eldoradoman is offline
post #21 of 29 Old 04-06-2009, 09:38 AM
rustynail
Didn't you just get new shocks? If I were you I would start with the springs and see how that feels. As far as shocks go, if you love off roading then you might want to research shock lengths. I had my heart set on the MX6's until I found out that they're a lot shorter than my RE monotubes.
I'm glad I researched this because my rear shocks allow 3 1/4" of droop and 6 3/4" of compression. If they were shorter I would not be happy. My front shocks have 11" of travel but I haven't taken those shock boots off yet so I don't know where they sit in relation to droop/compression.
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline
post #22 of 29 Old 04-06-2009, 09:47 AM
rugermack
They have them for a 3" lift, 1/2" wouldn't really make any noticable difference. Or just add the bar pin eliminator to get the 1/2" added.
post #23 of 29 Old 04-06-2009, 09:49 AM
Eldoradoman
Dude, he has the RC shocks that come with the 3.5" F>R swap kit from IRO, they are notorious for being very stiff. Rear springs should also be done at the same time though to help solve the jittery rear end & vibrations plus ride even better.
OP should measure hub to fender to see what the actual lift is. It seems a lot of 3.5" kits are really 4", RE springs for sure, so MX-6 or any shock designed for 3" lift would not ride like they should if you're really at 4".
post #24 of 29 Old 04-06-2009, 09:55 AM
rustynail
I figured that since they were new, he should give them a chance at least.
- Russ
post #25 of 29 Old 04-06-2009, 09:58 AM Thread Starter
kmk108
I should have notes the h2f the first time I talked about shocks. Idk about h2f but ground2f is 36" give or take a few cm
WHOEVER YOU MAY BE
kmk108 is offline
post #26 of 29 Old 04-06-2009, 10:04 AM
besthaticouldo
i would do the spring first dude.
if that doesnt solve it, then it likely would be the shocks.
check your front tie rods and your ball joints. i know i get a dead spot after hitting a bump and it drives me nuts.
i have bils on my ZJ and i love them. a great shock, i got them off of CL for super cheap used. but still very good...good luck getting the ZJ back to where you want.
besthaticouldo is offline
post #27 of 29 Old 04-06-2009, 11:20 AM
-Joseph
-Joseph's Avatar
I just did the IRO 3.5" lift with new rear springs about 2 weeks ago and my first impressions were a little sketchy like yours. Rides a little rough, but I knew that the new springs would do that. Bumpsteer was real bad until I got it aligned, now it's barely noticeable. The biggest thing is that I went out this weekend and run it in the dunes pretty good to see how stuff holds up and now its on-road manners have improved. I don't know if the springs settled or "broke-in" if there is such a thing but it feels a lot better after a thrashing. Doesn't seem as jittery or tippy, maybe it's just me. IMO though new springs are not going to make it ride better than used front springs, I would try thrashing it a little and go from there. As for the DW, I too vote for bad tie-rod ends and or ball joints. Good luck.
-Joseph
1995 ZJ Ltd. 5.2L 46RH
Swapped in NP 242
IRO 3.5"
Fauxmaster Muffler
30" BFG AT's wrapped around AR 767 wheels
-Joseph is offline
post #28 of 29 Old 04-06-2009, 06:49 PM Thread Starter
kmk108
-Joseph
the only thing is the spring rate for the fronts. Aren't they a lot tougher to compress than rears?
WHOEVER YOU MAY BE
kmk108 is offline
post #29 of 29 Old 05-08-2009, 01:50 PM Thread Starter
kmk108
I got a pair of rear RE springs and got them in. They are awesome compared to the stocks. My ride is still rough because of the shocks, but I can live with it for now.
WHOEVER YOU MAY BE
kmk108 is offline
anyone experience bad ride with 4" lift on WJ wonderbrd937 ZJ Grand Cherokee Forum 21 02-06-2009 10:19 PM
Tired of bouncy ride - WJ 2" lift NewAlbanyWJ ZJ Grand Cherokee Forum 21 02-04-2008 11:05 AM
Ride Quality of Lift EmpireTroy ZJ Grand Cherokee Forum 13 01-03-2007 11:46 AM
4" lift ride quality Mike WJUK ZJ Grand Cherokee Forum 4 09-24-2006 09:57 PM
WJ 4" lift and ride change Chandler ZJ Grand Cherokee Forum 16 09-13-2005 04:43 PM
