Got my lift on and now looking to improve ride - JeepForum.com
post #1 of 29 Old 04-05-2009, 07:30 PM Thread Starter
kmk108
I got my IRO lift on with the RC shocks they sent. I've been driving my jeep for almost a week now and Its terrible with ride quality. So I have a couple of questions.
1) If I want an immediate improvement in ride quality, what would be more important to get? New Control arms or better shocks? Keep in mind, I doubt it's ever going to be lifted any more than it is now.
2) If control arms are the answer, what control arms are most important first. I'm on a budget right now and can only get the most important arms now. LF, UF, LR, UR?
3) If shocks are the answer, what shocks should I get? I've spent about an hour searching through the threads and have gotten, "Get Monotubes...cuz...uhh...they're kick ***....yeeaaa." Give me at least one reason that I could relate to. I'm mostly driving my jeep on roads that have bumps. I would rather put up with a worse ride on the trails for a better ride on the streets. My jeep isn't under and heavy loads. Everythings stock (No metal bumpers, racks, or oversized spare in the back.
4) If there is anything else besides the control arms or shocks, input will help.
30 BFG A/T, Flowmaster Super40, Alpine head unit, Alpine amp, Rockford speakers, Sony subs, cobra cb
White Jeep Club Member #108
2009 FA CUP CHAMPIONS
CAREFREE, WHEREVER WE MAY BE
WE ARE THE FAMOUS CFC
AND WE DON'T GIVE A F@#K
WHOEVER YOU MAY BE
CUZ WE ARE THE FAMOUS CFC
kmk108 is offline
post #2 of 29 Old 04-05-2009, 07:52 PM
Art101
whats wrong with the ride quality... just saying that it sucks doesnt tell us much
is it to stiff?
are you all over the road?
do you get death wobble symptoms?
Art101 is offline
post #3 of 29 Old 04-05-2009, 07:54 PM
micifus
Original GC'er
micifus's Avatar
You are going to have the sacrefice some ride quailty when you go up in height.
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #4 of 29 Old 04-05-2009, 08:02 PM Thread Starter
kmk108
It is really stiff. I know that the lift will cause the ride quality to become fairly crappy, but this just doesn't seem right. I'm not all over the road. I had that and fixed it. I get death wobble vibes. I haven't had death wobble with everything connected and tight, but right now, I go over a bump and it feels like death wobble is breathing on my neck. I haven't taken my jeep on the highway because I would bet money it would happen. I drive over a couple speed bumps on the way to my gf's house. They aren't the bolt in, high, skinny ones. They are about 3 inches high and six inches wide. My front goes over it and it's rough, but the rear end goes over it and it feels like It gets a little air time, like there isn't enough weight in the back to push down the rear enough.
WHOEVER YOU MAY BE
kmk108 is offline
post #5 of 29 Old 04-05-2009, 08:18 PM
rustynail
Those springs were designed to carry an engine and now they're not, that is why they are stiff. Monotubes are stiff so don't run out and buy those. I don't think buying control arms is going to solve your problems either. I vote for buying Rubicon Express 3.5" rear springs because they are the softest on the market in that size if I'm not mistaken.
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline
post #6 of 29 Old 04-05-2009, 08:26 PM Thread Starter
kmk108
I was thinking about getting new springs eventually because mine were a little saggy. I was thinking about throwing a little weight in the back but wouldn't that just make them sag more? I just read that the new degrees that the stock arms are at make a big difference with ride quality.
WHOEVER YOU MAY BE
kmk108 is offline
post #7 of 29 Old 04-05-2009, 08:44 PM
rustynail
Yes a little bit, but mostly in the front. New control arms will do almost nothing for the rear. New lower control arms are about 1/2" to 1 1/2" longer which does not really change the angle much.
Are you unhappy with all of it or mostly the rear?
- Russ
post #8 of 29 Old 04-05-2009, 08:51 PM Thread Starter
kmk108
Only the rear. I thought about it more and now I'm thinking it's more the springs than anything. The front is about what I expected just a tiny bit rougher. I didn't think about the spring rate when I thought about the f>r. It just feels like I lose control in the rear because the jeep is so rough in the back. I'm going to drive it in a lil and it'll refresh me on the ride
WHOEVER YOU MAY BE
kmk108 is offline
post #9 of 29 Old 04-05-2009, 09:17 PM
Eldoradoman
Get proper springs for the rear for starters, then get some Bilsteins (budget permitting) or RE Montubes for a ride quality closer to stock.
1998 Bright Platinum 5.9, 242 swap, go-fast goodies ,and 3" exhaust w/Super 40, SCT Tuner, 4" hybrid lift, 33" Claw TTC Radials
Eldoradoman is offline
post #10 of 29 Old 04-05-2009, 09:31 PM Thread Starter
kmk108
These are the different opinions i've been seeing. Some people say that monotubes are too stiff and some say the ride quality is awesome.
Anyway, I just got back from my short drive to take my gf home and had the beginnings of death wobble. I've only had death wobble in the case of everyone on the road moving far away from me, so it could have been minor dw. What i noticed is that all wobble/vibration comes when I go over a bump with the rear. It's a little vibration in the front, which i expected, but when the rear goes over, its a little wobbly and freaky. idk if this is just from the ride being so rough or if there is a different problem that would also be contributing to the bad ride.
WHOEVER YOU MAY BE
kmk108 is offline
post #11 of 29 Old 04-05-2009, 09:35 PM Thread Starter
kmk108
Just looked up the re springs. If I can zero in the problem to being the springs, i guess i know what i'm spending my tax return on. and so continues the never-ending puzzle of the ideal lift. Wouldn't the world be such a good place if lifts were always perfect and you could get the best of everything?
WHOEVER YOU MAY BE
kmk108 is offline
post #12 of 29 Old 04-05-2009, 09:43 PM
Eldoradoman
Re-torque all suspension related components out back (track bar, shocks, control arms) first.
The RE Monotubes are one of the better riding Monotubes out there but are also great offroad with lots of flex/droop and don't cost an arm & a leg Great bang for your buck. I second the vote for RE springs for the rear as well.
post #13 of 29 Old 04-05-2009, 09:59 PM Thread Starter
kmk108
I just retightened everything on saturday, so i'm pretty sure it's not from loose bolts or components. One thing i did forget to check for was shot bushings. I'll get under tomorrow and try to eyeball those. I do have a feeling it's mainly the springs because everything is tight and i don't have the problem in the front.
WHOEVER YOU MAY BE
kmk108 is offline
post #14 of 29 Old 04-05-2009, 11:24 PM
NYC_ZJ
Jeep for LIFE!!
NYC_ZJ's Avatar
i also have a stiff rear spring feeling and if i put weight in the back (home depot trip or weekend luggage, even 2 people in the back seat) it does make the jeep much less jittery over bumps. I was also looking into new shocks to replace mine to get a better ride and the more i search the more confused i get. I've narrowed down all of the opions to either Bilstein's or MX-6's. But they're expensive so we'll see. Good luck and keep us posted as to your progress.
Oh, i've noticed that ALMOST all my DW is is gone is if i keep it in full time 4WD.
1996 ZJ - 4.0 w/ 164,000 miles
3" Rusty's springs, Bilstein 5150's, JKS Quicker Disco's, IRO Adj. Lower Control Arms, Rough Country SS, KOR's adj. TB conv. kit, JKS Rear Track Bar, IRO OTK Steering,
31x10.5x15 Goodyear Dura-trac's on Ultra Rogue Wheels
ZJs Only club member #58
NYC_ZJ is offline
post #15 of 29 Old 04-06-2009, 07:26 AM Thread Starter
kmk108
I only have fulltime 4wd and 4 lo. I was getting bad vibrations over bumps. I spent an afternoon going over all suspension and steering parts....nothing new. Yesterday I was driving and saw my 4wd selector was pushed back almost to N. I pushed it all the way forward and no more rattling or bad vibes...from the front
WHOEVER YOU MAY BE
kmk108 is offline
anyone experience bad ride with 4" lift on WJ wonderbrd937 ZJ Grand Cherokee Forum 21 02-06-2009 11:19 PM
Tired of bouncy ride - WJ 2" lift NewAlbanyWJ ZJ Grand Cherokee Forum 21 02-04-2008 12:05 PM
Ride Quality of Lift EmpireTroy ZJ Grand Cherokee Forum 13 01-03-2007 12:46 PM
4" lift ride quality Mike WJUK ZJ Grand Cherokee Forum 4 09-24-2006 10:57 PM
WJ 4" lift and ride change Chandler ZJ Grand Cherokee Forum 16 09-13-2005 05:43 PM
