Got my Build Sheet! - JeepForum.com
post #1 of 8 Old 04-07-2005, 04:05 PM Thread Starter
O Holy P
Got my Build Sheet!
Here it is:
Here is the list of factory installed equipment:
Prem Leather Trimmed Bucket Seats
Protection Group
Cold Weather Group
Luxury Group
Trailer Tow Group
Monotone Paint
Limited Decor Group
Radio - Cass/10-Disc./Infinity Spkrs
Quadra-Drive 4WD System
Smoker's Group
4.0L Engine(ERH)/4Spd Auto Trans(DGK
136 Amp Alternator
625 Amp Maintenance Free Battery
Anti-Lock 4-Wheel Disc Brakes
Low Back Bucket Seats
Highline Door Trim Panel
Rear 60/40 Folding Seat
Next Generation Front Air Bags**
Floor Carpet
Cargo Compartment Carpet
Cargo Net
Cargo Tie Down Loops
Front & Rear Floor Mats
Covered Cargo Storage
Door Sill Scuff Pads
Cargo Compartment Cover
Passenger Assist Handles
Mini Overhead Console
Full Length Floor Console
All 4-Speed Automatic Transmissions
4-Spd. Automatic 42RE Transmission
Lock-Up Torque Converter
Quadra-Trac II On Demand 4WD System
Dana 30/186MM Front Axle
3.73 Axle Ratio
Dana 44/226MM Rear Axle
Vari-Lok Progressive Front Axle
Vari-Lok Progressive Rear Axle
All Engines
4.0L Power Tech I-6 Engine
Tinted Windshield Glass
Front Door Tinted Glass
Deep Tint Sunscreen Glass
Flipper Liftgate Glass
Rear Window Defroster
Sun Visors w/Illum Vanity Mirrors
Rear View Auto Dim Mirror
Power Mirrors, Fold-Away
Power Sunroof
Remote Keyless Entry
Sentry Key Theft Deterrent System
Air Cond ATC w/Dual Zone Control
Hood Insulation
Deluxe Insulation Group
Instrument Cluster w/Tach
120 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Rear Window Wiper/Washer
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
Locking Glove Box
Power Accessory Delay
Power Locks
Power Windows, Driver One-Touch
Power 10-Way Heated Memory Seats
STRIPE/BADGE/MOLDING/COLOR
Illuminated Entry
Warning Chime
Vehicle Information Center
Courtesy Lamps
Glove Box Lamp
Ash Tray Lamp
Door Courtesy Lamps
Rear Courtesy/Reading Lamps
Underhood Lamp
Cargo Compartment Lamp
Traveler/Mini Trip Computer
Radio/Driver Seat/Mirrors Memory
Halogen Headlamps
Automatic Headlamps
Fog Lamps
CHMSL Lamp
Security Alarm
Body Color Grille
Black Windshield Moldings
Roof Rack
Quadra Drive Badge
Federal Emissions
20.5 Gallon Fuel Tank
Speed Control
Deep Slate Pearl Coat
Dark Slate Pearl Coat
All Radio Equipped Vehicles
AM/FM Cass Radio w/Changer Control
Infinity Speakers
Fixed Long Mast Antenna
10-Disc Remote CD Changer
Steering Wheel Mounted Audio Ctrls
Power Rack and Pinion Steering
Leather Wrapped Steering Wheel
Normal Duty Suspension
Tilt Steering Column
Inside Mounted Spare Tire
Full Size Matching Whl Spare Tire
P245/70R16 OWL All Terrain Tires
Goodyear Brand Tires
16X7.0 Lux Alum Silver Wheels
All Aluminum Wheels
Universal Garage Door Opener
Build To U S Market Specifications
7 Additional Gallons of Gas
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
GVW/Payload Rating
* DESCRIPTION NOT AVAILABLE ***
U.S. Dealer Retail
Zone 42-Detroit
Customer Preferred Package 2TK
Customer Preferred Package 26K
Customer Preferred Discount
Sold Vehicle
GA-Vehicle Family
JS-Vehicle Family
Label - U.S. Specifications
Michigan State Code
Michigan State Code
Few questions....what is the Smokers Group?? And I really don't think it has the Dana 44 axle in it, what's up with that?
Also, the windshield and front windows were not factory tinted, hmm?
Pretty cool tho.
pg
For Sale:
'99 Limited WJ - Deep Slate Pearl Coat
RB1 update, Rusty's 2.5", 255/70r16 Goodyear MTR's, Pro Comp MX6, Rancho RS5000 Stabilizer, 242 Swap, Gibson Exhaust !cat.
'95 z28 six speed - black w/ red stripes
solid roller 396ci LT1
O Holy P is offline
post #2 of 8 Old 04-07-2005, 04:11 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
Why do you think you do not have the D44 rear? If you have a real plug that screws in and out of the rear diff, you probably have the D44 you lucky dog. If you don't, someone has taken yours. (Bummer) It's all good for the most part.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #3 of 8 Old 04-07-2005, 04:25 PM Thread Starter
O Holy P
No Dana 44 then....it has a rubber pop in/out fill plug. :/
pg
For Sale:
O Holy P is offline
post #4 of 8 Old 04-07-2005, 04:38 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
It also says you have qudra-drive which is limted slip diffs in the fron't and rear. If i were you I would check closer into that D44 thing.
2013 FR-S
BlaineWasHere is offline
post #5 of 8 Old 04-07-2005, 04:53 PM
Flyinbrick
smoker's group got you the cig lighter, other wise it was just a plug (true for my TJ anyways)
-Michael-
1997 TJ
White Custom Long Arm with Blue Torch Fab Stretch
Wagoneer Dana 44 Front End w/ ARB, Currie Rockjock 60 Rear w/ Detroit, 37" Baja Claws, Poison Spyder Tire Carrier, Competition Corners, Flat Fenders, Front Stinger, Full roll cage, GenRight Fuel Cell, Snyper Fab Rocker Skids
Flyinbrick is offline
post #6 of 8 Old 04-07-2005, 07:30 PM Thread Starter
O Holy P
Well I took some pics, see if any of you can confirm that this is a D44. Not the best pics, but it was raining outside and i just stuck the camera under the car and started snapping.
http://host41.hrwebservices.net/%7Ew...%20rear%20end/
pg
For Sale:
O Holy P is offline
post #7 of 8 Old 04-07-2005, 09:05 PM
RAZZMANIAC
RAZZMANIAC's Avatar
As far as it being a Dana 44. . im sure it is. . . kinda looks like it. . .i also have a pop out plug on the right side. . . i think with the cheaper alluminum case it comes with just that. . . Dana 44 is kinda odd shapped, larger on the left and fatter on the left. . . the Dana 30 has kinda an oval shape. . .
www.off-road.com/jeep/tech/axle/d44.html
1997 Grand Cherokee 5.2L Tsi
RAZZMANIAC is offline
post #8 of 8 Old 04-07-2005, 09:12 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
the Dana 44a should be non-magnetic aluminium. Try checking with a magnet. The cover looked like steel, but the body should be AL.
As far as the windshield and front window tint go, they are tinted a little (15% maybe) but most states have laws against dark tinted windshield and front windows due to safety and law enforcement issues.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
Got my build sheet in Clintos ZJ Grand Cherokee Forum 0 12-23-2008 07:37 PM
Where is QD on a build sheet? ///BHRpowered ZJ Grand Cherokee Forum 8 08-10-2006 12:49 PM
Got my Build Sheet FivePointTwo ZJ Grand Cherokee Forum 5 07-24-2006 12:07 AM
Getting build sheet SteelBlue_WJ ZJ Grand Cherokee Forum 2 04-09-2006 09:41 AM
?'s on my build sheet jeepholic ZJ Grand Cherokee Forum 9 08-27-2004 07:50 PM
