Got Juice & Good Starter, Still Won't Start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Got Juice & Good Starter, Still Won't Start
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 08-14-2009, 05:56 PM   #1
bellisimo1
i have a 1999 4.7L that won't start. here's what i know:
when the key turns, it clicks once, right as the key is turned, and that's it.
the battery is newer, i charged it anyway for 48 hrs, tried jumping the jeep twice. the horn, radio etc. all work fine.
i pulled the starter and brought it to kragens. they bench tested it and it spun beautifully.
so, is this a computer thing, alarm or maybe fuse? i'm lost.
bellisimo1 is offline   Reply With Quote Quick reply to this message
Unread 08-14-2009, 06:13 PM   #2
micifus
Original GC'er
micifus's Avatar
If it clicks that leads me to believe its the starter. I have seen starters spin but then not turn under load. is power getting to the starter? You need to get a meter and check for voltage. Another thing you can try is whacking the starter with a rubber matter or a piece of wood
1993 Jeep Grand Cherokee Limited 4.0L I6
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
1970 Jeepster Commando 225 V6
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline   Reply With Quote Quick reply to this message
Unread 08-14-2009, 08:07 PM   #3
Double E
2000 Laredo V8
Double E's Avatar
Any chance the brake interlock system is the issue?
Can you tell us whan it last ran and how it was then? Were you driving?
Miles? Major service peformed recently?
Do you have a way to verify that the engine is not siezed? (remote chance, right?)
2000 Laredo 4.7L Selec-Trac. 177K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced 2X), new rear hatchglass struts, new radiator (replaced 3X), new oil pressure sending unit (replaced 4X), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3X), new rear shocks (replaced 2X), new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new sunroof assembly, new single-piece lug nuts, new exhaust manifold studs & gasket on driver's side, new Durango alternator. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
Double E is offline   Reply With Quote Quick reply to this message
Unread 08-14-2009, 08:23 PM   #4
Turbonut
My vote. Usually if an interlock/alarm problem, the starter won't engage.
Turbonut is offline   Reply With Quote Quick reply to this message
Unread 08-14-2009, 08:54 PM   #5
micifus
Original GC'er
micifus's Avatar
the alram should not allow the relay to click though I would think.
32"x11.5" BFG A/T
4" Lift
Unread 08-15-2009, 12:07 AM   #6
bellisimo1
i'm guessing the one click that i hear is the gear engaging with the flywheel, but then it must not have enough juice to turn. i am going to try cleaning the corrosion off the connecters and try again (fun). if that doesn't work, i'm not really sure what's next. i really hope it's not seized, although i have no idea why it would be.
Unread 08-15-2009, 07:57 PM   #7
JkTheItalianoWJ
my 2000 wj gave me problems starting every once in a while it was getting plenty of power and everything was fine workin radio, alarm, etc. mine would start most of the time but not start from time to time and i talked to a few people and they said maybe its your fuel pump but then i let it go for a little while and my check engine light came on and i had the code read and come to find out my cam shaft positioning sensor was bad, idk if that helps you out at all but i figured id give you another option to try out
JkTheItalianoWJ is offline   Reply With Quote Quick reply to this message
Unread 08-17-2009, 01:24 PM   #8
bellisimo1
since i know you've all been losing sleep over this, i thought i'd give a quick update. i cleaned all the contact points for the starter with a wire brush to remove any corrosion, and then re-installed it. the damn thing worked! hope this helps some else in the future.
Unread 08-17-2009, 02:30 PM   #9
txtumbleweed
Could also be a bad/weak battery cell
Y2K WJ 4.7
txtumbleweed is offline   Reply With Quote Quick reply to this message
Unread 08-17-2009, 02:49 PM   #10
driabyor
1994 ZJ
check the voltage at the starter... starters need 10+ volts to engage the solenoid
as stated above bad battery ....
loose connection ....
dirty cable ends ... including the ones connected to the starter
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline   Reply With Quote Quick reply to this message
