got a clunk - JeepForum.com
post #1 of 3 Old 11-10-2001, 05:39 PM Thread Starter
Kess
got a clunk
i have a 94 zj 4l and when crusing down the road there is a clunk in the front passenger area, does ne one have ne ideas what this is sometimes it sounds liek its in the suspension sometimes sounds right under the gear shifer, like tranny/transfer case, its starting to piss me off thanx for ne input
In comission:2004 WJ, stock....
Retired:1994 JGC Laredo I6 4.0L, Smittybilt Outland brush guard, 1 3/4" Daystar coil spacers, custom air intake with tube K&N, Borla cat-back, KC Daylighters 6" 150w stainless steel, Xenon superwhite headlights 85/100w, 235/75/15 Pirelli Scorpian A/T, billit aluminum grill inserts
Kess is offline
post #2 of 3 Old 11-18-2001, 10:15 PM
normdo
Check your front sway bar bushings...the ones from the bar to the frame of the vehicle. I had the same noise and new bushings fixed it. This seems to be very common on Grand Cherokee's. Make sure you get polyurethane ones so you won't have the same problem again. Good luck.
normdo is offline
post #3 of 3 Old 11-19-2001, 02:57 PM Thread Starter
Kess
i was actually under my jeep the other day and noticed metal to metal contact area around that area, and that bushing is all dry rot, worn to about 1/4in, i had a feeling it might be that also cuz my dad had a similar noise in his TJ and those bushings fixed that, ur a life saver, thought it was gonna be something expensive, but since you had like the same sound, it makes the diagnosis that much easier, thanx!
Kess is offline
Rear end clunk, clunk - found the problem - how do I fix it? Camo WJ Grand Cherokee Forum 19 02-25-2011 02:20 PM
New RE Twin Tubes + Cold = clunk clunk clunk? DHRFX Joe ZJ Grand Cherokee Forum 12 01-23-2009 08:03 AM
My WJ likes to go, clunk clunk clunk. kwb18 ZJ Grand Cherokee Forum 16 05-29-2007 03:59 PM
Clunk clunk front end suspension noise. Need help/advise. jeep_zj98 ZJ Grand Cherokee Forum 11 01-02-2007 10:22 AM
Rear clunk, clunk, clunk Camo ZJ Grand Cherokee Forum 10 11-24-2005 08:17 AM
