Good Value Exhaust??? - JeepForum.com
post #1 of 27 Old 05-09-2011, 10:34 AM Thread Starter
ScottyGunn
I need to replace the muffler and tailpipe. I could use this as an excuse to upgrade, ;0)
Any suggestions on a system that will be better than stock for MPG but won't cost me an arm and a leg? I don't want a real loud system, but I do like a little bit of throaty rumble.
Newby with first Jeep!
ScottyGunn is offline
post #2 of 27 Old 05-09-2011, 10:39 AM
Dyn0mitemat
The $30 autozone/advanced thrush or cherry bomb turbo both sound about the same, which is a nice rumble but not too loud
Dyn0mitemat is offline
post #3 of 27 Old 05-09-2011, 10:51 AM Thread Starter
ScottyGunn
Do I need to start at the headers with a bigger diameter system to get better breathing or is that just something that is a myth and doesn't really help MPG?
post #4 of 27 Old 05-09-2011, 11:01 AM
ajmorell
ajmorell's Avatar
You probably won't notice much increase at all in MPG to be honest, but starting from the headers back is the way to do it.
ajmorell is offline
post #5 of 27 Old 05-09-2011, 01:38 PM
Apollo24
I would love to hear what aftermarket ($200-$400) exhausts people are using. I just bought another 98zj and never had to change exhausts on previous jeeps I owned. This one has an annoying leaking.
Apollo24 is offline
post #6 of 27 Old 05-09-2011, 01:54 PM
ajmorell
ajmorell's Avatar
You can see what I'm running in my profile
Banks Torquetube header, custom downpipe, magnaflow high flow converter, 2.5" mandrel bent all the way out through a FM50
ajmorell is offline
post #7 of 27 Old 05-09-2011, 01:57 PM Thread Starter
ScottyGunn
I just talked to a guy down at a local garage who I know that has a lifted Jeep. He thinks a Cherrybomb and 2 1/2" pipe is enough. I looked at Rusty's Offroad and found this:
http://rustysoffroad.com/mm5/merchan...y_Code=PER_EXH
It is only CAT back, but if there wouldn't be any noticeable improvement in MPG or pick-up then I guess it doesn't make sense to start at the block??
post #8 of 27 Old 05-09-2011, 02:21 PM
ajmorell
ajmorell's Avatar
I can't say there isn't any difference doing it from the header back, but for sure you won't notice a difference from only the cat back. It also helps tremendously if you upgrade the intake side as well. If you couple those two you will notice a difference.
ajmorell is offline
post #9 of 27 Old 05-09-2011, 02:23 PM
Kolak
Vendor
Kolak's Avatar
If you're going to replace the entire exhaust, send me a PM with your email address and I'll send you all the information about my Kolak Exhaust. It's a 3" diameter system and includes a high flow converter as well as a muffler, and a mandrel bent tailpipe. JeepForum members get 10% off my regular prices.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #10 of 27 Old 05-09-2011, 02:25 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Do the cat too. Its probably not flowing well if its the original.
HighLonesome is offline
post #11 of 27 Old 05-09-2011, 02:43 PM Thread Starter
ScottyGunn
What kind of CAT does it use? I see a bunch of options for ports, etc....
post #12 of 27 Old 05-09-2011, 02:48 PM
HighLonesome
I used a Magnaflow universal fit. Passed NM emissions easily. Check with Kolak, pretty sure no ports necessary.
post #13 of 27 Old 05-09-2011, 02:58 PM Thread Starter
ScottyGunn
How loud is the Magnaflow? I use this rig hunting so I don't want to scare off everything in the woods, lol.
post #14 of 27 Old 05-09-2011, 03:29 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
You tube has some jeeps with different exhaust installed so you can get an idea what they will sound like. As it stands right now I'm thinking about a APN header, stock exhaust pipe, direct fit magnaflow cat,and the magnaflow cat back. Not looking for mpg's cause it wont make that much difference, but want to fix the leaks and get rid of the cell.
coralman is offline
post #15 of 27 Old 05-09-2011, 03:39 PM
ajmorell
ajmorell's Avatar
The converter won't make a huge huge difference in sound, well at least not nearly as much as the muffler selection will.
ajmorell is offline
good price on MBRP exhaust CRD micky_blue WK Grand Cherokee & XK Commander Forum 9 08-24-2009 02:59 PM
Good options for replacing entire exhaust, including downpipe? John in MA ZJ Grand Cherokee Forum 5 08-10-2008 11:43 PM
Exhaust manifolds as advertised on this page; Any good? MG McAnick ZJ Grand Cherokee Forum 5 04-20-2007 08:29 AM
ZJ Exhaust: 3" good or bad? ZJ_Spartan ZJ Grand Cherokee Forum 13 02-20-2006 12:50 AM
any exhaust pics or good experiences for GCL supdawg ZJ Grand Cherokee Forum 2 01-25-2002 12:59 AM
